suspensions C3,1978
Old Oct 19, 2008 | 04:20 PM
vettelink78's Avatar
vettelink78
1st Gear
Default suspensions C3,1978
I have a 1978 vet that I bought as a basket case. Much of the front suspension is missing. I have found used suspension for C4 and C5 corvettes but very few C3 suspensions. I would like to know if the C4 or C5 suspensions are better suspension than the C3 and if the C4 or C5 will fit in my 78 without any problems or alterations.
Old Oct 19, 2008 | 05:40 PM
Gordonm's Avatar
Gordonm
Yes the C4 and C5 are better. They will not fit your car without major modifications. C3 parts are quite easy to come by. Check the Corvette junkyards or ebay and sometimes they pop up here. You can always buy new from the vendors here on the forum also.
Old Oct 20, 2008 | 03:04 AM
thomson2008's Avatar
thomson2008
3rd Gear
the Corvette has only become more renowned as the years drift by. Undergoing many changes and restyles as any other vehicle will over the years, the Corvette has experienced new engines, transmission, chassis, features, body colors and so much more. Starting with a 235 cu-in 6-cylinder engine, the Corvette has since switched to a V8 with a horsepower that is improving each year. Over the years, the Corvette has also been offered in different trim models, the hardtops, coupes, convertibles, ZR-1s and Z06.
________________________________________ ____
Thomson
Our mission is to provide high quality end to end solutions to the BPO segment in a manner that will improve the operational efficiency while reducing the cost of the services to the client.
4thdimension1@gmail.com
Old Oct 20, 2008 | 02:48 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Almost all your front suspension pieces are regular GM. Literally millions of them made. Post in the Parts Wanted forum.
To suspensions C3,1978
