unknown vaccum hose.
Old Oct 19, 2008 | 10:17 PM
namvet6869's Avatar
namvet6869
Default unknown vaccum hose.
today on my 81, i found a real small plastic vaccum hose just hanging on the right side of the engine comp. near the fender well. it has a rubber end on it with a circular type lock on it.it runs into the firewall near the right side of the distributor along with three other of the same type. smog pump is missing and also ac comp. is gone. also would like to know the proper connections of vaccum hoses to the carb and air cleaner. any help would be appreciated. thanks namvet.
Old Oct 19, 2008 | 10:19 PM
Durango_Boy's Avatar
Durango_Boy
I think that small vac line goes to the heater hose shutoff valve.
Old Oct 20, 2008 | 07:42 PM
namvet6869's Avatar
namvet6869
thanks Darango, wasnt nothing hooked to the heater valve so i put it there. what does it do anyway????????? heater worked without this hooked up. maybe valve is stuck!!!!!!!!!!! namvet
Old Oct 20, 2008 | 09:21 PM
7T1vette's Avatar
7T1vette
That valve is to shut off the water supply to the heater (functions in OFF and A/C MAX settings, I believe).
To unknown vaccum hose.
