torque on monospring mount plate
Old Oct 20, 2008 | 03:05 PM
Bowerss2's Avatar
Bowerss2
Default torque on monospring mount plate
What should i torque the mount plate bolts for a fiberglass mono spring from VBandP, factory spec seems like it might be a bit high for fiberglass
Old Oct 20, 2008 | 04:04 PM
another-user's Avatar
another-user
going off memory, it was 40 or 45Lbs. it should be on the installation sheet that came with the spring.
Old Oct 20, 2008 | 04:23 PM
77TexVette's Avatar
77TexVette
Torque specs sheet from VBP :
http://www.vbandp.com/instructions/h...specsR0102.htm
They only list specs for tightening the steel spring, which is 70ft lbs. I guess the composite spring torque must indeed be in the instructions and my guess is that is is a bit less than 70.
The mounting pads are some type of plastic and could probably crack or crumble if overtightened.
Let me know what you find out. If in doubt: 727 345-5292 (VBP)
M.
Old Oct 20, 2008 | 05:05 PM
another-user
knew i saw it in the instructions.
http://www.vbandp.com/instructions/42300.pdf
63-79 is 40-45Lbs.
To torque on monospring mount plate
