84 question
Old Oct 23, 2008 | 11:08 AM
bret.dittmer's Avatar
bret.dittmer
3rd Gear
Default 84 question
My wife drove my 84 in a homecoming parade and it loaded up on her by the time the parade was done. I've changed the plugs hoping this was the problem but it wasn't. I'm thinking the fuel filter should be changed next. ? where is the fuel filter?
Old Oct 23, 2008 | 11:17 AM
bradc6's Avatar
bradc6
St. Jude Donor '05-'06-'07-'08-'09-'10-'11
National Champs Gators 4 St. Jude '09
You might have better luck posting this in the C4 section.
Old Oct 23, 2008 | 05:06 PM
Durango_Boy's Avatar
Durango_Boy
What exactly do you mean by 'loaded up'?
Old Oct 23, 2008 | 07:25 PM
tnovot's Avatar
tnovot
To the best of my recollection, the filter is on the inside frame rail, passenger side about midway between the front/rear tires.
Two things to remember:
There might be pressure in the line which can be relieved at a TBI inlet or by barely lossening one of the fittings on the filter and maybe wrapping it with a rag to keep it from squirting you in the face.
The filter is lower than the gas tank so have the new one ready to install.
A bad fuel filter would starve the engine for fuel rather than cause the engine to "load up" in the most common meaning of the term.
Terry
Old Oct 24, 2008 | 04:35 PM
divitasbluepitbulls's Avatar
divitasbluepitbulls
lurk:Would like to hear the anwser
Old Oct 24, 2008 | 05:54 PM
vettebuyer6369's Avatar
vettebuyer6369
Pretty sure the C4 questions work best on the C4 forum.
Old Oct 24, 2008 | 06:02 PM
rcread's Avatar
rcread
C1 = 1953-1962 (known by us old folks as "solid axles")
C2 = 1963-1967 (known by us old folks as "mid-years")
C3 = 1968-1982 (known by us old folks as "sharks")
C4 = 1984-1996 (unknown to us old folks)
C5 = 1997-2004 (unknown to us old folks)
C6 = 2005-???? (unknown to us old folks)
Old Oct 24, 2008 | 08:38 PM
earthquake68's Avatar
earthquake68
Well, When I had my C-4, The fuel filter is a standard GM fuel filter located passenger side, where the frame curves inward to clear the front suspension. It's mounted to the frame rail itself. If your exhaust is black, check the ground for the computer on the back of the driver's side cylender head, and make sure it is tight. If that's ok, I'd probably change the M.A.P. sensor. (passenger side of the intake towards the rear. It has a three pin connector and a vacuum line going to it)
Hope this helps.
Old Oct 24, 2008 | 08:40 PM
earthquake68
Old Oct 24, 2008 | 09:57 PM
paulywannafly's Avatar
paulywannafly
check the coupler between pump and sender . fuel bypass makes them run stinking rich due to lack of fuel pressure. little 1nch section of hose bloats and they run like crap
To 84 question
