Calling All block code breakers please
Old Oct 26, 2008 | 07:28 PM
MadMarx's Avatar
MadMarx
Default Calling All block code breakers please
Here are the numbers on my block:
Front pad # CEA12974 7
Rear driver's side # 3970010
Also 28 GM
Rear pass side # \ 3 - (round nub) A61
What do you think?
Old Oct 26, 2008 | 07:34 PM
hammadown's Avatar
hammadown
Also 28 GM
What do you think?
3970010 is the same #on my block......72 350 base 200hp
Hammadown
Old Oct 26, 2008 | 08:01 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
CEA 1980 305 auto trans. 155hp 4V
3970010....302.....69....4V...Z-28 Camaro
3970010....327.....69....2V...Trucks and industrial
3970010....350.....69-80...2V or 4V
Old Oct 26, 2008 | 08:23 PM
MadMarx's Avatar
MadMarx
Oh that's not good.
I think I'm going to have to pay the previous owner another visit!!!
So it's a low HP 1980 350 engine?
That's the only possibility?
Old Oct 26, 2008 | 08:39 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
What do you think?
3970010 = 1969-1980 350ci
A61 = January 6, 1971
CEA12974 = Chevrolet Engine from Flint engine plant #12,974 (sometimes called a Counter Exchange or Crate Engine - Flint CE numbers were 00001-19999 and 80001-89999 - the "A" in "CEA" is some kind of internal identification, as is the ending "7").
If this block is in your 1969, it may well be a Warranty Replacement, especially if other engine parts appear to be original (heads, manifold, carb, etc ...).
Old Oct 26, 2008 | 08:48 PM
Mike Ward's Avatar
Mike Ward
Franks got it right!
Old Oct 26, 2008 | 09:04 PM
MadMarx's Avatar
MadMarx
I certainly hope so. The previous owner swore it was a numbers matching car since he has owned it since '73.
I knew it wasn't, but I was under the impression it was an exchange engine put in during the original owner's time.
It has camel hump heads I think. I haven't removed the valve covers yet.
Other parts look to be original but I will look for more numbers.
Is there a site that shows where the numbers are located on other parts?
Old Oct 26, 2008 | 09:09 PM
Mike Ward's Avatar
Mike Ward
The best you can hope for is that it was a direct warranty exchange engine and is similar/identical to the original. It could equally have been sitting in a taxi or dump truck for 30 years and been installed in your car just before you bought it.
CE engines were not identified or tracked in a way that provides absolute proof of internal components.
Old Oct 26, 2008 | 09:13 PM
MadMarx's Avatar
MadMarx
You had to say that didn't you!!
I actually started feeling a little better about the whole thing 'til you dropped that on me.
I have the original owners name so my plan is to see if he's still around.
Thanks for the input.
Old Oct 26, 2008 | 09:22 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
If there isn't any accompanying paperwork, the point will be moot.
Good Luck.
Old Oct 26, 2008 | 11:53 PM
wfo76's Avatar
wfo76
Just to add to what Frank said, my take on the 'A' in CEA is that was the solution they came up with when they ran out of numbers. The range numbers I show is 00001-19999 for Flint 6-cyl, 20000 to 49999 for Flint V8 and 50000 to 79999 for Tonawanda. If Flint needed to supply more than 30,000 warranty V8 engines, then they were screwed as number 50000 and up were Tonawanda numbers, so they just added the A and then started over again at 20000.
To Calling All block code breakers please
