Headlight Questions
Old Oct 27, 2008 | 12:44 PM
corvette_maniac's Avatar
corvette_maniac
Default Headlight Questions
Well .....I've been back on the road now for a couple of weeks and so now I'm beginning to see all of the "other" things that need attention. One being the headlights. I've swapped an actuator and the bolt's/washers for each headlight's connection to the actuator assy. However - one of the headlamp assemblies has a crack at the bolt hole and both are loose at the upper hinges. Last night, I drove it home with some foam wedges just to make it home without pissing too many people off because of flapping headlights.
My questions are, is there a stop adjustment for the up travel? I can lift each headlight an inch when the lights are on.
The other question is, should I just convert to something else, being that the cracks and play might be more expensive than just converting?
Sorry to be so long winded. Any help - or pics would be appreciated.
Old Oct 31, 2008 | 05:41 PM
corvette_maniac
For whatever reason, the j-bars have nothing to limit their travel on either side. Is there supposed to be a rubber piece at the frame?
And, does the j-bar contact that rubber piece before the vacuum actuator is fully extended keeping the headlights from flapping around?
Old Nov 1, 2008 | 09:11 PM
corvette_maniac
No help?
Old Nov 1, 2008 | 09:22 PM
babylonvette's Avatar
babylonvette
maybe something frozen or out of ajustment because when the headlights are all the way up the brace has a bolt on it ,on the outside of the assembly, it hits the housind which holds it steady,not realy a good description but you should get the idea when looking under the car at the headlights when full up
Old Nov 1, 2008 | 09:30 PM
...Roger...'s Avatar
...Roger...
I agree with the above post.Here is GMs procedure.
To Headlight Questions
