Uh oh... steering problems. Advice needed!
I've been having issues with my steering. Just this week it started clicking when I turn the wheel while backing out of the driveway. When I turn the wheel far to the right or left (not really in the center) the column is making this clicking noise that sounds like metal on metal.
I decided to poke around a bit under the hood and saw this (probably another issue altogether)....
Notice the bolt is missing the the middle of the above pic. Should that disc be warped like that? Here's a pic of the other side (wheel rotated) with the second bolt intact, but the same warping. I'm a virgin when it comes to cars so expert (or even novice) opinions welcome. What part is this and should I be concerned? Can I put a bolt and nut through there or does the whole assembly need to be replaced?
http://wiki.corvettefaq.com/index.php?title=Main_Page
That`s not good...
go to search, type in rag joint...
More guys will chime in...
Rod
Love the Vette
http://jimshea.corvettefaq.com/?page_id=4
From your pictures I think that you have a 1968 Corvette with a telescoping steering column. (It is quite important to give this type of information in your posting.) Assuming I am correct about the year of your Vette I suggest that you purchase an OEM flexible coupling GM part #7806391 to replace the part that you have in the car.
The OEM style flexible coupling has stop pins that are hot staked in place and also has shoulder bolts that attach it to the column flange. If you want to learn more about this particular part I suggest you go to www.corvettefaq.com
click on Jim Shea's Steering Articles
click on Corvette Steering Papers
scroll down to the section on Flexible Couplings.
Jim
May I use your photographs in my papers to explain the safety issues when using some of the flexible coupling rebuild kits that are on the market. Your pictures are priceless in explaining exactly the kind of problem that I have been concerned about.
BTW, I was the engineering supervisor of the flexible coupling group at Saginaw Steering Gear Division, General Motors Corp back in the 1970s and early 1980s when our C3s were in production. So I do have considerable experience with these steering system parts.
I have written to many Corvette suppliers over a year ago explaining the need for bolts with shoulders to provide a metal to metal connection when making attachments through rubber parts such as the flexible coupling disc. I got a very few responses that indicated that they were making their supplier aware of my engineering concerns. Nobody has ever gotten back to indicate that fasteners in the rebuild "kits" have been corrected by using shoulder bolts.
The following sketch shows the parts that I am concerned about.
One last question: I cannot see in your photographs what type of bolt is being used to attach the flex coupling flange to the steering gear. It should be a special bolt (GM #7807271) and is available at GM dealerships and from many suppliers. It should NOT be just a common bolt. BTW, it is the same bolt that is being used to attach the steering column flange to the steering column shaft.
Thank you,
Jim Shea
Jim
The Vette in the picture was very close to completely losing steering. This is a critical safety issue.
BTW, I also sent a message to NHTSA through their websight about a year ago about this very subject. I never heard back from them either.
Jim
You assemble the flexible coupling all the way until it bottoms out on the gear input shaft. Then tighten the special 7807271 pinch bolt. Tolerance between the steering column and the gear is taken up by the flange on the steering column. That flange has about 1/2 inch of adjustment up and down on the steering column shaft.
1968 and early 1969 steering gears had input shaft with full round splines. 7806391 is the correct flexible coupling with a flange that has full round splines.
Late 69 through 82 gears had an input shaft with a flat machined at 12 o'clock with the gear exactly on center. 7818568 is the correct flexible coupling for this gear. It has a flange that has a matching flat.
I think that both flexible couplings come with orange plastic spacers attached to the stop pins. They assist in centralizing the steering column to the flexible coupling on the steering gear. There is limited adjustment of the lower end of the steering column (up and down as well as side to side) by loosening the two nuts inside the car where the steering column tube meets the floor. You want the steering column to be pointing exactly at the steering gear. Once you attach the flexible coupling to the steering column flange you can pull the plastic spacers and throw them away. The stop pins on the flexible coupling should be central in the slots of the steering column flange.
There is a procedure for aligning the steering column and the steering gear in the AIM.
Jim
Jim
Any recommendations on a good place to purchase that OEM part online? Regarding the pics, you're welcome to use them for your site. You guys have already helped me solve 2-3 issues with my car, and that wouldn't have been possible unless someone had shared the information.
http://www.zip-products.com/Corvette...0B5DD4559C5265
Available at Corvette Steering Service
http://www.corvettesteering.com/corvette%20parts.htm
Also available a www.gmpartsdirect.com by plugging in the correct GM part number.
If you see the flexible coupling for something like $49 it is most likely made offshore. If the cost is roughly $89 it is most likely a GM part.
From your picture it appears that you will still need a 7807271 pinch bolt. You will also have to purchase a 3/8-24 nut and lockwasher and a 5/16-24 nut and lockwasher.
Jim
Result? Wow! What a difference in steering! No more wander and the effect is to have the steering at least twice as responsive as before - easily now within spec for a road trip. Seeing as the rest of my suspension is refreshed I will have the box rebuilt if steering slop again becomes an issue...
Thanks Jim - and forum members for the info I needed to order, then install these parts!
Thanks, Jim. Maybe you should learn to read. My exact words were "use the same size and grade of bolt". [Your description of what bolt to use was already listed just above my post.]
