Dwell Setting
Old Oct 30, 2008 | 12:42 AM
Marino's Avatar
Marino
Default Dwell Setting
I have a 1969 stock 427/390 and no manual. Can anyone tell me what the point gap ,dwell angle and timing should be set at? Any help would be appreciated.
Old Oct 30, 2008 | 06:25 AM
Gordonm's Avatar
Gordonm
The stock settings call for a point gap of .019 and a dwell of 28-32. The stock timing is 4 BTDC
Old Oct 30, 2008 | 08:35 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I run my 390 horse dwell at 30. You will probably find the factory spec on timing a little "retarded". 12 degrees initial is more like it depending on whatever it takes to get to around 36 degrees at about 2800 RPM's.
Old Oct 30, 2008 | 06:17 PM
Alan 71's Avatar
Alan 71
Hi Marino,
I'm just KIDDING but.... you should not be allowed to own a GREAT car like that if you haven't bought the GM CHASSIS SERVICE MANUAL for 69!!!
Have Fun!
Regards,
Alan
Old Oct 30, 2008 | 09:26 PM
earthquake68's Avatar
earthquake68
Points?! What are those?!
j/k. ALL Chevy V-8's were set to 30 degrees dwell. No exceptions. Capevette is right about the timing. Stock tends to be a little sluggish. I don't know that I'd go to 12 degrees right off though. Maybe 8. But hey, that's just me. The full advance of 36 is right in the ball park. You'll need an advance light to know where total timing is.
Old Oct 30, 2008 | 10:19 PM
Mike Ward's Avatar
Mike Ward
It's actually a gap of .019 or a dwell of 28-32 degrees. Simply two difference ways of measuring the same thing.
Old Oct 30, 2008 | 11:27 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I would put the points in the range mentioned. However, while you are setting the dwell, it’s a good time to check for distributor bushing wear. If you bring up the RPMS after you set the dwell, see if it increases. If the dwell increases you have a problem in the distributor bushings.
When the dwell increases with RPM’s, the upper bushing is worn and allowing the distributor shaft to move when torque is applied.
Willcox Inc.
Old Oct 31, 2008 | 12:10 AM
clintwilson's Avatar
clintwilson
30 degrees dwell.
Old Nov 3, 2008 | 10:36 PM
vett us all's Avatar
vett us all
Match cover.
Old Nov 4, 2008 | 07:29 PM
Marino's Avatar
Marino
Sorry it took a while to get back, but I appreciate all the help guys. Thanks
To Dwell Setting
