Rattle in engine
Old Nov 1, 2008 | 09:10 PM
racedazed's Avatar
racedazed
Cruising
Default Rattle in engine
Need some guidance. I've got a 78. Starts fine. Idles fine. I notice when I shift it into gear, the rpms drop and I hear a raddle. Goes away when I shift it back into P and let the rpms come up. My first thought was a broken valve spring or rod bearing but it should raddle at idle also. It's an automatic transmission. Any suggestions on what to check first?
Thanks,
Todd
Old Nov 1, 2008 | 09:18 PM
Skip Burney's Avatar
Skip Burney
Have you checked for a cracked flex plate I had the same thing in a pickup truck of mine and it caused the exact same rattle
