Quick side pipe question
Old Nov 6, 2008 | 07:39 AM
DaJesterMan's Avatar
DaJesterMan
Default Quick side pipe question
Hey!
When installing side pipes, why do some 'vettes have the metal molding below the door removed and some do not? I have seen pictures both ways and have always wondered if trimming is required to get the molding to fit...
-Keegan
Old Nov 6, 2008 | 01:39 PM
joewill's Avatar
joewill
i have seen both too, mine actually replaced the rocker moldings and screwed into the same tapped holes.
Old Nov 6, 2008 | 01:41 PM
Quil's Avatar
Quil
Sometimes they have to be modified to fit. Mine, luckily, did not.
Old Nov 6, 2008 | 01:55 PM
Jay-Dog's Avatar
Jay-Dog
I suppose some folks would prefer to keep them in the garage rather than butcher them. On mine, no trimming was needed.
Jay
Old Nov 6, 2008 | 02:04 PM
guitarcrazy02's Avatar
guitarcrazy02
Mine fit fine. Just took a little massaging to get them in.
Old Nov 6, 2008 | 05:07 PM
lock-n-load's Avatar
lock-n-load
I have seen some that sit below the moulding ...
I like the look but might be tuff over speed bumps ..
Old Nov 6, 2008 | 11:02 PM
TimAT's Avatar
TimAT
I need to trim a little bit of the rocker molding where the pipes come out from under the front. They were trimmed with the other headers, but these new ones set just a little different. I'll take a 3" diameter drum sander and open them up. Don't know about the SB guys, but I've got 2-1/8 primary tubes and they do take a bunch of room.
Old Nov 7, 2008 | 08:16 AM
DaJesterMan
Thanks for the info guys! I was thinking the same thing... I am getting a set of used Hookers with 2-1/8 primary tubes also, so I may end up having to butcher the molding. I just think a car with side pipes but without that molding looks incomplete...
Old Nov 7, 2008 | 10:23 AM
stevelischynsky's Avatar
stevelischynsky
So who's headers and side pipe combination do you use that requires no mods?
Steve L>
Old Nov 7, 2008 | 11:19 AM
DaJesterMan
I believe the Hooker Supercomp side pipe setup and the 4 inch side pipe which is sold for C3's takes very little modification. There are lots of old posts on this topic if you do a search for side pipes
Old Nov 7, 2008 | 09:38 PM
Rodbuster's Avatar
Rodbuster
Default Hooker
Had to trim one side about 1/4 inch
[http://s116.photobucket.com/albums/o...t=IMG_2482.jpg
To Quick side pipe question
