cover for outdoor storage
Old Nov 10, 2008 | 06:49 PM
LT1driver's Avatar
LT1driver
Default cover for outdoor storage
need a cover that will stand up to high wind without ripping/shredding in west texas aread.....any recommendations???? indoor storage is not an option. thanks
Old Nov 10, 2008 | 07:13 PM
68/70Vette's Avatar
68/70Vette
Can you put up a canopy? The canopy will keep rain and dew off of the car cover. I found out the hard way that you cannot store a car outdoors for any extended period, under only a car cover, without a lot of corrossion/humidity damage. And that was in the relatively dry So. California weather. A canopy is relatively cheap....about $150 or so.
The canopy does relatively well with winds, but it must be placed along side a building.
Old Nov 10, 2008 | 08:52 PM
Fast81's Avatar
Fast81
www.shelter-logic.com
Did alot of research, these guys have their act together
Old Nov 10, 2008 | 10:22 PM
LT1driver's Avatar
LT1driver
place won't let me put up something like that, fenced in storage lot, asphalt.
Old Nov 10, 2008 | 11:24 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Wolf Noah. $190.
http://www.wolfautocovers.com/Wolf-Car-Covers.html
Old Nov 11, 2008 | 08:18 AM
Wuttin's Avatar
Wuttin
Originally Posted by xccter
I agree, you can get the same one from Zip for ~$150. It has grommets at the base of each door to lock it on (cable or bungee) so wind is not an issue. It will NOT however block out all water...once the initial treatment wears off it let's some water through, but dries out pretty quick.
Old Nov 11, 2008 | 08:43 AM
jgrigg's Avatar
jgrigg
Default What about a portable garage.
If you're looking for something semi-permanent, check out HF. I've had this portable garage for a couple of years now. Held up to Michigan summers and winters. I think it runs about 159.00. They also sell replacement covers for about 60.00. I just replaced my cover for the first time this fall.
They don't give you lots of room to work, but I've been able to do most everything short of bodywork & paint while the car was inside of it.
http://www.harborfreightusa.com/usa/...bCategoryName=
Old Nov 11, 2008 | 08:49 AM
FlyViper's Avatar
FlyViper
In my experience, that shelter will not hold up to strong winds. I used to have one for another car a few years ago. I came home one day and found the car sitting there on the side of the house and the shelter laying in a mangled mess in the backyard. The wind picked it up and threw it over the house! I liked the shelter otherwise, but the thing acts like a kite in high winds.
Old Nov 11, 2008 | 10:29 AM
jgrigg's Avatar
jgrigg
I avoided this situation by actually anchoring down the structure with concrete. (What a concept!) Dug holes, put concrete in holes, placed eye bolt in the hole upside down let set. Put J bolt throught the eye and run throught the pre-drilled holes along the bottom of the structures sides. Hasn't been moved by winds up to 80mph over the last few years. Or mabye the wind storms in Michigan just aren't as fierce as in the rest of the world.
Old Nov 11, 2008 | 12:34 PM
FKING1's Avatar
FKING1
I have a Noah Wolf (2 yrs old) on my 70 outdoors summer only in Michigan.
Rain soaks through and onto the paint on horizontal surfaces. Dirt carried in with the rain puts a dirty film on the paint surface. Car is waxed and dirt wipes off with Quick Detailer. Cover has also ripped in several places from high wind.
I would not recommend this cover and I am looking to buy something rain resistant.
Old Nov 11, 2008 | 01:47 PM
68/70Vette's Avatar
68/70Vette
I'm on my second canopy (shelter). The basic design is that the tubing is slip fit. The canopy fits conformally over the tubing and that fit and friction holds the entire thing together. However, in severe winds, the canopy begins deflecting and some of the tubing works loose and then the entire thing collapses....and then can actually blow away. To improve durability, I drilled all of the tubing slip junctions and inserted a stainless steel metal sheet screw. Now the tubes can't come loose. Also I've weighted all of the legs. Also the canopy sits between a tall brick wall and between my house and garage. This keeps the blunt force of the wind down. And finally, the original canopy was very tall. I've cut the legs off (metal cut off bench machine) to lower the canopy close to the car. I have a Noah car cover on the car and the overall result is very good. I really do need a garage. One thing about the wind here (probably Texas too) is that it has a lot of fine sand in it. After a strong wind episode, I have to use my air gun and blow dust out of the engine compartment, clean engine chrome. My 68 is a convert. and somewhat air tight, but dust gets in the interior also and it has to be removed since the sand seems to have a bit of salt in it. oisthedn v
Old Nov 11, 2008 | 03:04 PM
garage-ghost's Avatar
garage-ghost
Find some indoor storage.....you don't ever want to store any car outside...you WILL get some type of deterioration. A car cover will whip around in the wind no mater how tight you think you have it and there goes your paint.
To cover for outdoor storage
