1975 Steering Box
Old Nov 12, 2008 | 05:34 PM
GOLDEN65CPE's Avatar
GOLDEN65CPE
Default 1975 Steering Box
What is the correct finish on the steering gear box and Pitman Arm. I can find nothing in the NCRS Judging manual. I've seen natural cast metal finish and I've seen black. Any help would be appreciated.
Thanks, AL
Old Nov 12, 2008 | 08:38 PM
stock76's Avatar
stock76
Maybe someone here can give you an expert, for sure, answer. My 1976 box was original to the car and clearly had never been painted. Both it, and the pitman arm were just a raw, as-cast finish. When I rebuilt it, I left it that way with just a light oil coating on the exterior. I have owned the car since 1982 so I know it had not been tampered with since then. Don't know for sure on a 75 but I'll guess it's the same - no paint. Hope that helps you a little.
Old Nov 12, 2008 | 09:15 PM
7T1vette's Avatar
7T1vette
I don't know about your year, but earlier C3's are 'correct' with either semi-gloss black paint or bare cast iron finish. I have mine off right now (it is a '71 and was bare metal) and am going to use hi-temp engine enamel in "cast iron" color to preserve it a bit better. Not 'correct', but it will appear to be correct. At least, then I can wash it and not have it rust.
To 1975 Steering Box
