Question regarding build sheets
Old Nov 17, 2008 | 10:03 AM
rick1025's Avatar
rick1025
Default Question regarding build sheets
Regarding the build sheet (corvette Order Copy)
Should the ident No. in the upper left corner corespond to the VIN number?I have the order copy from my car and all is correct ,except the ID # and the VIN dont match. Any answers would be appreciated. Thanks,Rick
Old Nov 17, 2008 | 10:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by rick1025
...Should the ident No. in the upper left corner corespond to the VIN number?...
No. Not on the older cars. (These days it might.) It is my understranding, the ident number for the older cars was entered in Detroit after an order for a new Corvette was received. It was for internal tracking purposes only and did not correspond to the VIN.
Old Nov 17, 2008 | 10:35 AM
IrishJoker's Avatar
IrishJoker
This document you have is it Landscape or Portrait in form? My build sheet has the VIN in block 9. The document should be landscape in nature with block 9 in the UPPER Right Corner. In Block 9 only the actual build number of the car is in typewriter print, the first part is computer generated that's because the vehicle production Identification number was added on the assemply line.
Also it helps if you state what year you are talking about. The form changed design over the years. Below is an example of the landscape form document used in later years to date I guess.
Here is my build sheet for a 1981:
Old Nov 17, 2008 | 02:59 PM
Easy Mike's Avatar
Easy Mike
'66 shown; later years are similar. ident number center left has no correlation to the VIN.
Old Nov 17, 2008 | 05:27 PM
hunt4cleanair's Avatar
hunt4cleanair
The Ident No. (identification control number) was assigned by the St Louis factory and printed in the upper left hand corner of the Corvette Order Copy. It had (factory) its in-house system for job identification and its relationship was indirect to the VIN. The factory transitioned to the landscape type manifest (true build sheets) in 73. As you've correctly stated...before 73 it was a copy of the Corvette Order Copy...a sales document.
I'm guessing you have a pre 73 Corvette...but not as early as 67.
Old Nov 17, 2008 | 09:00 PM
rick1025's Avatar
rick1025
I have a very early 68. Oct 23 67 build.435 / m-21/ black-black-black-black. 35,000 orig mil4es ,although I think they may have been put on 1/4 mi at a time!! Bought the car years ago and am just now getting the time to restore it. The interior is in very good shape ,but it was painted yellow some where along the line.The person I purchased it from gave me the "build Sheet" and everything matches except that one #. Thanks everyone for the info. rick
Old Nov 18, 2008 | 11:17 AM
halfmoontrail's Avatar
halfmoontrail
The last 3 digits of the VIN should be hand-written in "grease pencil", or less 500 if over 500.
Also, the last 4 digits of the VIN are usually hand-written in regular pencil.
Steve
Old Nov 18, 2008 | 01:50 PM
Easy Mike's Avatar
Easy Mike
...The person I purchased it from gave me the "build Sheet" and everything matches except that one #. ...
You're good to go.
To Question regarding build sheets
