Plug Wires - Help me untangle these!
Old Nov 17, 2008 | 05:34 PM
Emeightch's Avatar
Emeightch
Default Plug Wires - Help me untangle these!
As the title says, anyone have a good way to hide/organize these?
Old Nov 17, 2008 | 05:40 PM
Durango_Boy's Avatar
Durango_Boy
I like the Crossfire distributor caps because they put the plug wires on the same side as the cylinder they go to. Then find a loom that runs the wires along the valve cover. This is an example of a center bolt valve cover loom, but you can find all kinds that work for the perimeter bolt valve covers.
Old Nov 17, 2008 | 06:33 PM
Ironcross's Avatar
Ironcross
Yep, clean that puppy right up. we-ill get them out of sight. .
fortunately you have 90 degree sparkplug boots and the wires look adequate as to length.
Run your plug wires underneath the manifolds {headers} to the rear of the engine and up the back along the bellhousing to the distributor. It will clean that mess you have right up and present a well organized engine with wiring that is out of sight and out of mind. This works for small blocks or big blocks.
Old Nov 17, 2008 | 06:56 PM
Greg Slater's Avatar
Greg Slater
Navigator
Sorry about hijacking But Durango were did you get the serpentine set up? Is stock GM or aftermarket?
To Plug Wires - Help me untangle these!
