which header?
Old Nov 21, 2008 | 01:10 AM
steve dalla's Avatar
steve dalla
Default which header?
i have an 1980 corvette with a 350, AFR heads. currently i have a set of cheap Flowtech headers. they are very tight on 2 of the plugs and i keep burnin up my wires. i would not mind spending some cash on a real nice set that is full length and set up to work well with what i have. any suggestions from u would be great. btw i want to keep full exhaust, no sidepipes. thanks
Old Nov 21, 2008 | 08:06 AM
Cleon's Avatar
Cleon
I have a 1979 and installed a set of Hooker long tube. and true duels. Has worked well
no problem with spark plug wires.
Old Nov 21, 2008 | 12:19 PM
C3 4ME's Avatar
C3 4ME
I have Hooker Super Comps on mine, no complaints at all. I have factory A/C and it's a 4 spd, and no fitment issues. I would recommend having them ceramic coated as I did, but not from the factory. Order htem plain, fit them up, then send them off to be coated, just in case there is a fitment issue.
Old Nov 21, 2008 | 04:27 PM
Crab's Avatar
Crab
I've got Dynomax ceramic coated headers with true dual Maggies. I did have a problem with heat melting a plug wire. I don't recall which plug, but I went with shorty plugs and that solved the heat/ melting problems. I think the Dynomax were about $310.00 from Summit two years ago and they fit great, no bending or denting to get them to fit and no leaks
Old Nov 21, 2008 | 08:00 PM
tjl82's Avatar
tjl82
hedman elite , had to use shorty plugs , header fit is excellent
Old Nov 21, 2008 | 09:34 PM
tigers123's Avatar
tigers123
I went with the Sanderson cast headers. I believe they have a lot of flow. qp1000 I think.[model number] The ports on them more than big enough for the AFR's. I was concerned that 1 and 5/8 headers would not work with the AFR's. Your paying for flow there and you don't want tubes smaller than the ports on the heads. I did this research by matching the felpro exhaust gasket AFR calls out for the head with the headers I had and decided to get the Sanderson's Also these cast Sanderson's are going to allow plenty of room for the jeep steering box as they really hug the cylinder head. So I won't be cooking the steering box. And they are ceramic coated. Seeing how you can't hardly wear them out look for a used set on ebay if you want them.
Old Nov 21, 2008 | 10:11 PM
c3corvette77's Avatar
c3corvette77
hooker long tube pro comps. they say these won't work with angle plugs though.
Old Nov 22, 2008 | 10:07 AM
MN80Vette's Avatar
MN80Vette
I have long tube ceramic coated Dynomax headers on my '80 and like them a lot. I switched from block huggers because I had major spark plug boot burn problems, no spark plug clearance on 2 cylinders, and they melted my motor mounts.
Note that if you choose full length headers, your left pipe will need a really sharp bend to route it to the right side like stock. Here's a picture showing the problem:
Instead, I recommend you route the left pipe near-straight back like this:
You will need to modify your cross member to get the same ground clearance under the left pipe as you have under the right. The modification is pretty simple to do with an air cutoff tool and a short piece of 4" exhaust pipe.
Old Nov 22, 2008 | 10:36 AM
John D.'s Avatar
John D.
Went with Hooker Long tube ceramic coated on my 71 with 2.5 " chamber exhaust no fit problem and so far no plug problem. I would say fit is tight but works. I installed them from bottom up so car needs to be raised. Sorry no installed pictures at this time.
O8 Roadster Crystal Red Matellic with Cashmier interior.
Old Nov 23, 2008 | 09:16 PM
Grumpy 427's Avatar
Grumpy 427
Any body have clearance issue with the shift linkage on a TH-350. Mine is too close for my liking. i need to see if i can figure out what header they are? What header fits well with a 2-1/2 " pipe and a TH-350?
To which header?
