82 corvette radio removal
Old Nov 25, 2008 | 08:28 AM
cpmman's Avatar
cpmman
Default 82 corvette radio removal
How do you remove a radio for an 82 corvette? Through the front panel or out the back/side.
Old Nov 25, 2008 | 08:31 AM
Durango_Boy's Avatar
Durango_Boy
It has to come out the back. The bezel is flat on the front minus the holes for the radio *****. You'll have to pull out the gauge bezel with the radio still in it. Then you can pull off the ***** and the retaining nuts and remove the radio.
Why are you removing the radio?
Old Nov 25, 2008 | 11:15 AM
cpmman's Avatar
cpmman
Putting a restored stock radio back in.
How much of the side console needs to be removed to gain access to the back?
Old Nov 25, 2008 | 11:19 AM
Durango_Boy
You can remove just the gauge bezel but you will need to remove both transmission tunnel side panels to access the screws that hold the gauge bezel to the shifter panel. There is one on either side and the screws hold the to panels together at that seam.
Old Nov 25, 2008 | 01:46 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Here's where you'll find yourself! I also removed the fasteners for the console plate(don't remove it) to gain a little wiggle room. Handle things with care, that old plastic can be brittle.
Old Nov 25, 2008 | 03:05 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
CPMMAN: Do yourself a favor and purchase the '82 assembly instruction manual. The AIM will show you the factory installation, including the hidden screws at the bottom of the bezel.
Trust me. AIMs are worth their cost!
To 82 corvette radio removal
