427 casting codes question - 435HP; IL code?
Old Nov 25, 2008 | 09:20 AM
Wolfgang5150's Avatar
Wolfgang5150
Default 427 casting codes question - 435HP; IL code?
Confused here. Looking at a 1968 427 block; code is 3935439 (430,435HP), but the suffix is stamped 'IL', which matches up to a 390HP manual trans.
Shouldn't the suffix be 'IM', or 'IR'?
Thanks in advance.
Kevin S.
Orchard Park, NY
Old Nov 25, 2008 | 09:22 AM
Wolfgang5150
Nevermind; just realized it's a 1969 block........
too many damn numbers....
Old Nov 25, 2008 | 11:01 AM
Wolfgang5150
Or is it? Need some help.
Here are the codes:
Block 3935439
Heads 3931063
Suffix T07I6IL
And if it is a 68, how do you explain the 'IL' code on a 439 block?
I'm losing my mind with all these codes & numbers floating around.....
Thanks in advance.
Kevin S.
Orchard Park, NY
Old Nov 25, 2008 | 11:20 AM
wfo76's Avatar
wfo76
My pocket NCRS guide shows the 3935439 block used (late) with all 68 big block engines
Suffixes
- IL (390hp 4-spd)
- IQ (390hp auto)
- IM (400hp 4-spd)
- IO (400hp auto)
The 3931063 heads it shows as 69 390/400hp heads.
Do you have a 390 or 400hp car?
Old Nov 25, 2008 | 12:28 PM
FrankVincent's Avatar
FrankVincent
Account disabled by user request 5 Jan 09
Here are the codes:
Block 3935439
Heads 3931063
Suffix T07I6IL
Orchard Park, NY
3935439 = late1968/early1969 427/390hp (2 bolt) or 400/435/430hp (4 bolt).
3931063 = 1969 427/390 or 400hp heads
T0716IL = Tonawanda, July 16, 1968, 427/390/QuadJet/4speed
the casting number does not determine the HP. You can check the dates on the block (passenger side, starter area) and the dates of the heads to confirm ... the heads appear to be replacement.
Old Nov 25, 2008 | 01:51 PM
Wolfgang5150
Thanks!! Great info - (I live about 10 miles away from the Tonawanda plant; wonder if there's any old parts lying around!)
Kevin S.
Orchard Park, NY
Old Nov 25, 2008 | 02:57 PM
FrankVincent
Kevin S.
Orchard Park, NY
after some further research, you should also know that some late 1968 engines had those heads, so they may be original. Check the casting date to confirm ... if the heads casting date is before July 16, they are probably original to the block.
additionally, there should be a partial VIN on the pad, right next to the build date. Is it there??
Old Nov 25, 2008 | 03:44 PM
Wolfgang5150
frank - I will check.
To 427 casting codes question - 435HP; IL code?
