Door issues
Old Nov 26, 2008 | 10:08 AM
coby petersen's Avatar
coby petersen
1st Gear
Default Door issues
I'm having trouble getting my 69' vettes drivers door to operate from the inside? How do I fix this?
Old Nov 26, 2008 | 10:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the '69 assembly instruction manual (AIM). The AIM shows the factory installation of the various door opening and locking rods.
If the interior door opening handle will not open the door, the rod may be disconnected or bent. If the handle appears to open the door, but the door is sticking, the latch mechanism might need a good cleaning and lube.
Old Nov 26, 2008 | 01:08 PM
GD70's Avatar
GD70
Pull the door panel off and you'll see how everything works and what isn't.
Don't forget to remove the 4 panel clip screws on the door edges. You'll need to hold the inside door handle in the open position to access the screw so you can pull it off, and you'll also need the retaining clip tool to remove the window crank and lock **** clips.
To Door issues
