70 lt1
Old Nov 27, 2008 | 03:15 PM
mvette76's Avatar
mvette76
Default 70 lt1
how do you verify a that a 70 lt1 is and lt1. going to look at one today
Old Nov 27, 2008 | 04:51 PM
...Roger...'s Avatar
...Roger...
Engine suffix codes are a good place to start.My black book shows CTK,CTR,CTU and CTV.(if its ctv the book says its a zr1=$$$$$)It should have a transistor ignition.Look up front left side behind headlights for amplifier.
Some other guys will chime in and give you some other items to check.
Old Nov 27, 2008 | 05:08 PM
66L36Coupe's Avatar
66L36Coupe
...also look for a single fuel line to the fuel pump w/o a return line, and check for HD caps attaching the half-shaft u-joints rather than the U-bolt configuration used on lower hp small blocks. The tach should also be 6500 redline. No AC was offered in LT1's 'cept in '72. Of course, it should also have a big-block type hood that hasn't been drilled for the "454" script.
Old Nov 28, 2008 | 10:45 AM
Alan 71's Avatar
Alan 71
Take a look at member David Mayhew's posts. He developed a really complete list of things to look for in a real LT-1. It should be fairly easy to find.
Besides 427/435 cars, I think LT-1s are the most frequently 'made-up' cars. It's where the SB $$$ are.
After you've seen the car, you might want to contact Drew Papsun from Connecticut. For many years he's been running a survey on known LT-1 cars. It would be great to know if this car is part of his survey..
I think LT-1's are great cars, good luck!
Regards,
Alan
Old Nov 28, 2008 | 12:50 PM
Solid LT1's Avatar
Solid LT1
1970 LT-1 have K-66 TI ignition, big copper brass raditor, HD caps in side yokes, 6500 red line tach, big 6qt oil pan, and single fuel lines. Most people would need build sheet or other documentation to verify. Even if K-66 amplifier is missing there should be signs of TI wiring harness and other items to help verification of LT-1 Vette.
Old Nov 28, 2008 | 02:17 PM
PRNDL's Avatar
PRNDL
If I was looking at a purported 1970 LT-1, the first thing I would look for would be the fuel return line. That is one of the easiest things to check, pretty much proof positive of a fake if it is there, and a very easy thing to overlook if somebody is creating a fake LT-1. If it was an old beat up car... even NOM.. if there was no fuel return line I would be inclined to give it the benefit of the doubt. However, if it was a complete frame off concourse restoration then I would be more skeptical and would rely more heavily on documentation.
I have said in the past that if I were buying an LT-1 I would just buy a 72 (engine is in the vin).
Old Nov 28, 2008 | 04:50 PM
Ironcross's Avatar
Ironcross
Check the tach, the red line should be higher, at least 6500 for a 70 LT1 engine.
probably the best 1970 Vette built and of the LT1`s of any year. No de-tuning of the engine as later ones. ...
Old Nov 28, 2008 | 04:53 PM
...Roger...
Old Nov 28, 2008 | 10:51 PM
dbeall1968's Avatar
dbeall1968
Is yellow? A convertible, in a barn next to some farm equipment, off the road since '95? We just went through that with one guy, and I don't know if he ever bought it. Next Q is what is it worth- look up 70 LT1 barn find from about 3 weeks ago. Lots of info on the 70 LT1. Good hunting!
Old Nov 29, 2008 | 11:55 PM
StickShiftCorvette's Avatar
StickShiftCorvette
QUESTION: If '70 LT-1s came with 6 quart oil pans, was power steering NOT available on those cars?
I had to loose my Chevrolet 6 qt oil pan when I added power steering to my modded '69 convertible.
Old Nov 30, 2008 | 01:58 AM
LT1driver's Avatar
LT1driver
70 lt1 only got ps in later vins and then had a 5 qt pan so steering rod would work, this is what I have been told. remember that 70 was short model year due to GM strike with only 1287 built that year
Old Nov 30, 2008 | 07:59 AM
mstanton's Avatar
mstanton
Early 70 LT-1s had a CTU engine suffix and came with 6 quart oil pan. Power steering was not available. Starting in late April, a 5 quart oil pan was used and the engine suffix changed to CTK. Power steering was available with the CTK engine.
Old Nov 30, 2008 | 11:19 PM
LT1driver's Avatar
LT1driver
Not 100% true, my old 70 LT-1 birth date was may and it had the CTU engine codel.
Old Nov 30, 2008 | 11:47 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
I'll bite though... how did the "look" go?
Old Dec 1, 2008 | 11:26 AM
427-390's Avatar
427-390
Old Dec 1, 2008 | 08:47 PM
mstanton's Avatar
mstanton
I didn't mean to imply that all May LT-1s were CTK, just that the change was begun in late April. I don't think there were any April CTK cars or any June CTU but May could probably be either, particularly early May. When was your engine and car's build?
Old Dec 1, 2008 | 10:08 PM
mvette76's Avatar
mvette76
it was gone before me and the old man could get out there?
To 70 lt1
Old Dec 3, 2008 | 01:02 AM
Solid LT1's Avatar
Solid LT1
I keep on hearing that story of "late production" power steering. I only know, I had a late June 70 build LT-1 coupe and it had the 6qt pan my 70 roadster with a F22 (June 22, 1970) build date also has a 6qt pan (and Corvette Steering Service "Jeep box" power steering to keep the wife happy ) I have yet to see a legitimate LT-1 built in 1970 with power steering on it (except for my "rare" factory prototype roadster, it also has a rare "factory prototype" TKO-600 RR 5 speed option, first one ever donee, Yeah! Yeah! THAT'S THE TICKET!)
1970 LT-1 with power steering? I DON'T BUY IT!
Old Dec 3, 2008 | 08:25 AM
mstanton's Avatar
mstanton
Did your car have a CTU or CTK block? My first 70 LT-1 had a F27 (June 27) body build and a CTK block built in 6 June. It did not have ps but did have the smaller 5 quart pan. My current 70 LT-1 is a Feb build with a CTU block and the larger oil pan.
Old Dec 3, 2008 | 08:53 AM
GD70's Avatar
GD70
It should also have the AIR smog system which all LT-1's had, or if removed, the holes on the manifolds should be plugged.
I've posted these pics before of my friends 70 LT-1 engine but I think this is a good reference for anyone looking at a LT-1. His has the 6 qt oil pan, though he told me that the water pump is not correct at the time I took these pics, but he was replacing it.
Hope this helps.
Good luck, Glenn
