Battery cable grommet
Old Dec 5, 2008 | 09:52 AM
rev1949's Avatar
rev1949
5th Gear
Default Battery cable grommet
Anyone found grommets for the battery cables for C3 cars without buying a cable set?
rev1949
Old Dec 5, 2008 | 10:21 AM
Durango_Boy's Avatar
Durango_Boy
rev1949
Unless you want Vette specific grommets you can buy them individually in most hard ware and automotive stores, and most will have at least one that will fit both the hole and the cable.
Old Dec 5, 2008 | 11:23 AM
eusdawb's Avatar
eusdawb
Hi Durango Boy
I meant to ask you what is probably a stupid question. I'm going to be installing an amp this winter and have followed a lot of your suggestions on other threads. Where can I find the hardware for connecting the power and ground to the battery terminals? I have seen some products used to change out the actual terminals that add extra wire termination position for the amp wires. Is it easier to find some other hardware to connect the wires to a normal 2 post battery?
Old Dec 5, 2008 | 11:30 AM
Durango_Boy
Originally Posted by eusdawb
Hi Durango Boy
I'm going to send you a PM about this so we don't take this thread off topic.
Old Dec 5, 2008 | 06:14 PM
Alan 71's Avatar
Alan 71
Hi Rev,
Dr Rebuild usually has the largest selection of soft parts like grommets, but I didn't see them listed.
How about a call to some of the harness manufacturers, maybe they'd sell them separately.
Regards,
Alan
Old Dec 5, 2008 | 06:59 PM
Edzred72's Avatar
Edzred72
I was looking for them too, and ended up calling a salvage yard. I still had to buy used cables from them to get the exact grommits.
Eddie
Old Dec 5, 2008 | 08:14 PM
1nicecorvette's Avatar
1nicecorvette
i am going to have an old negative cable in a week or so that will have an original grommet on it if you really need it. It may be a while though as its only 26 here right now.
To Battery cable grommet
