carb problem??
Old Dec 11, 2008 | 03:13 PM
kend47's Avatar
kend47
Default carb problem??
I have 77 SB L48 and when I put my foot in it, it bogs down to the point of stopping completely. I am thinking of replacing the carb, but could it be something else causing the performance problem? I want to make sure I look at everything before I spend tall $$ for replacement Where is a good place to order new carb?
Old Dec 11, 2008 | 03:30 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Could be an advance problem?
Old Dec 11, 2008 | 04:13 PM
Durango_Boy's Avatar
Durango_Boy
Whoa don't go replacing the carb just yet. Sounds like a couple different things might cause that and they are just adjustments.
First, does it do the same thing no matter if the engine is cold or hot and running for a while?
The first things that come to mind are choke, timing, and accelerator pump...which can be replaced instead of the whole carb.
Old Dec 11, 2008 | 07:09 PM
my 76 ray's Avatar
my 76 ray
Sounds like the Accelerator Pump to me. It's not too hard to replace.
Old Dec 11, 2008 | 07:52 PM
bojangies46's Avatar
bojangies46
First I would check timing, check plugs to see if running rich or bad, plug wires and make sure your timing is advancing.
Old Dec 11, 2008 | 09:19 PM
c3corvette77's Avatar
c3corvette77
i had an 84 camaro with a rochester that did the same thing. the carb needed to be rebuilt, there was an internal leak. might not be a bad idea to check the fuel pump and your filters as well.
Old Dec 12, 2008 | 03:03 PM
kend47's Avatar
kend47
Thanks. Hot/cold.running for a while, it still happens. The cost of the new one is not cheap. I will check the three items you suggested.
To carb problem??
