What engine is this?
Old Dec 13, 2008 | 02:47 PM
Too Slow '90's Avatar
Too Slow '90
Default What engine is this?
I looked at a '72 today and found that the motor was not original. The pad number is V0282400. Does anybody know what engine this is?
Thanks,
Roy
Old Dec 13, 2008 | 02:50 PM
Durango_Boy's Avatar
Durango_Boy
Thanks,
Roy
What's the casting number and date on the bell house webbing?
Old Dec 13, 2008 | 02:52 PM
Mike Ward's Avatar
Mike Ward
Don't know, but it was apparently built on February 82nd.
Old Dec 13, 2008 | 03:03 PM
Too Slow '90
I left without getting the casting numbers and was not sure if anything could be obtained from the pad numbers...other than Feb 82nd.
Roy
Old Dec 14, 2008 | 04:06 AM
1975greenconvertible's Avatar
Aren't the last 3 digits supposed to be letters, not numbers? You can get alot of decoding info at YearOne's website.
Old Dec 14, 2008 | 09:09 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
http://www.mortec.com/
http://www.nastyz28.com/gm-chevy-cod...s-suffix-2.php
Old Dec 14, 2008 | 04:54 PM
speedreed8's Avatar
speedreed8
my 79 L82 has the same type numbers on the block pad, VO ?? 2500, i cant remember the first two numbers. no VIN data. it has the correct L82 intake, correct camshaft , 4 bolt main block,(no windage tray), and the heads are standard heads, when i pulled the bearings they had GM 81 on the back of them, i havent found any info to explain the numbers, i think its probably a dealer service replacement long block manuf. in 1981. the casting numbers on the back of the block indicate it was for i think 78-82 350 engine. so yours may be an over the counter block replacement . just fyi
To What engine is this?
