Engine detailing
Old Mar 5, 2009 | 10:59 PM
  #41
dmayhew's Avatar
dmayhew
I have been doing a lot of taping off and painting different areas under the hood for the past 2 years. But was never really pleased with the look. The work I have seen here from others that cleaned with the motor installed is simply amazing. I finally decided to take the motor out to do a more detailed job that I had been able to do.
Old Mar 5, 2009 | 11:05 PM
  #42
randommj's Avatar
randommj
Originally Posted by Vettebuyer5869
You can do a nice job on a '69 without taking the motor out in no time...
I always feel overwhelmed with all the crap AROUND the engine, how do you get all that stuff? just do a corner a weekend? Im assuming you have to take a lot out to paint it?
Miles
Old Mar 6, 2009 | 08:06 AM
  #43
car71's Avatar
car71
[QUOTE=SEVNT6;1568197669]I did mine in the car along with the firewall. Quite the pain but worth it in the end. I like Dupli-Color which I used on everything.....
did you use primer under that dupli-color, and what grit was use to sand it down. looks great.
Old Mar 6, 2009 | 09:30 AM
  #44
69monzacpe's Avatar
69monzacpe
Hey hammadown,
I like your oil filler cap. Where'd you get it, or did you customize one?
Old Mar 6, 2009 | 09:36 AM
  #45
69monzacpe's Avatar
69monzacpe
Originally Posted by 400hp427vette
Wow, Great work by everyone Anyone have any ideas on how to clean my intake without removing it from the car?
I use spray carbureator cleaner and a rag. I cover any painted parts while doing it so I don't get overspray on them. It's best to remove as many parts as possible from the top of the engine which makes the job much easier.
Old Mar 6, 2009 | 09:51 AM
  #46
emmvette's Avatar
emmvette
All of your engines and compartments look so great it makes me want to add this to my project list for next winter! Awesome!
Old Mar 6, 2009 | 07:33 PM
  #47
hammadown's Avatar
hammadown
Originally Posted by 69monzacpe
Hey hammadown,
Thanx....... yeah I got the idea from someone on this forum
I purchased the piece from Zip.......
http://www.zip-corvette.com/Zip/dept...D0A882F78C2C9A
It has adheasive but I used a 2 part bonding product to lock it on
Hammadown
Old Mar 6, 2009 | 08:10 PM
  #48
VictoriaVette's Avatar
VictoriaVette
Some GREAT looking jobs I need to do some detailing on my 77 also.
Old Mar 6, 2009 | 11:10 PM
  #49
GPGG70's Avatar
GPGG70
I really like these threads. The engine detailing that is. Most of you that have posted your engine pictures to other threads in the past has inspired me as well. I learned a lot by studying your engine bays and have found new things to do with mine. Most of the time I can look at someones engine bay and fine some little detail that I've over looked or thought to myself, now that looks great and applied it to my work on my car.
Even in this thread I've noticed a car re-routing the vacuum hoses under the brake booster, also anouther re-routing the hoses going to the vapor cannister as well. It really cleaned up the look of the engine.
I'm still working on my engine bay and will post pics when it's finished but not yet. I'm sure I have at least 2 more months more work on it.
Thanks for all your help whether you knew it of not.
Old Mar 7, 2009 | 12:21 AM
  #50
wallifishrmn's Avatar
wallifishrmn
What is everyone using on the exhaust manifolds. I did mine once but the heat takes it off with time. Mine look like Alan's 71 in color; Dave's and others look more aluminum color than mine--mine are darker. The NCRS judging just says the were cast iron and the engine was painted before assembly--doesn't state color of exhaust==natural color?
Old Mar 7, 2009 | 01:27 AM
  #51
vettebuyer6369's Avatar
vettebuyer6369
Miles
I take a lot off, but it's not bad. air cleaners, ignition shielding, hoses in the way... you'll know what to do. The key is to degrease it real good, then slowly restore one spot at a time, taking your time. Never rush. Do a little and walk away. Use different tones and colors of black and grey, rather than blasting everything the same flat black. Think detail, be careful of overspray on hoses, wires and bolts that shouldnt be painted. Take small metal parts off and clean and scrub them. Use new items like hoses, clamps, caps, etc. Research the correct finishes for different parts if you want a correct look.And take the extra time to tape of places that need to not be painted. Details, details.
NCRS wants a natural finish. Thats one thing I just cant do... rusty exhaust manifolds (and brake master cylinders) are just not acceptable to me. I always use Eastwood's Stainless Steel Coating on the exhaust manifolds. Looks like a million bucks, lasts forever. Stinks at first, but it goes away. Others use a couple other similar products that also work, but its Eastwood's for me.
Old Mar 8, 2009 | 10:19 AM
  #52
GPGG70's Avatar
GPGG70
Bump.
Old Mar 8, 2009 | 12:30 PM
  #53
hammadown's Avatar
hammadown
I think you are overwhelmed by all the various hoses and vacuum lines
and the task of taping everything is daunting to say the least
but ............ tin foil can be your best friend and makes the job soooo much easier . just grab a hand full of hoses or wires and wrap with the foil. theres really only 4 sections to be wrapped front/firewall & left /right sides. when your done with the bulk of it the single or small items are all thats left
And this is when I repaired the radiator
Hammadown
Old Mar 8, 2009 | 12:40 PM
  #54
Alan 71's Avatar
Alan 71
It's AMAZING what people come up with to get 'THE LOOK'!!!!!! If only we were getting PAID by the hour.
Regards,
Alan
Old Mar 8, 2009 | 09:13 PM
  #55
70Yellowbird's Avatar
70Yellowbird
Any chance you could post pics of your exhaust manifolds finished with Eastwood's Stainless Steel Coating?
I'd love to see how they look.
Also, when you prep the exhaust manifolds do you grind off the 'fins' and other protrusions from the casting process before painting?
Thanks.
