Looking at a C3
I know from reading the forum to look at as much of the birdcage as possible. From this, I see to pull the top trim of windshield off, kick panels, and some panel on the inside of rear wheelwells, as well as checking under the car for rust on the frame. Is that it?
Here's other things I've noticed on the interior:
Seats are in good shape
Seat belts don't pull out
Door panels are loose at the bottoms (both)
Tach doesn't work
Radio doesn't work
Other gauges may/may not work
Speedo works OK
T-tops seem a little "loose"; doubt they are watertight. One of the interior t-top panels is drooping at one corner
It's a stock 350 4 speed, engine may not be original, but it's rebuilt. To be honest, I haven't checked the numbers on the motor because I don't know where to look.
The guy bought this car a couple years ago, and supposedly his wife doesn't like riding in it. He's not real mechanically inclined, and I think he's not gung ho on me starting to tear apart the inside of the car checking out the birdcage.
Are there some simple, quick procedure documented for pulling the kick panels, the trim, and the rear wheel well cover panels? I couldn't find them, and I don't want to be bumbling around if he's already nervous.
Also, given the car's birdcage checks out, with all the interior problems, what would be a good ballpark price for this car? As I said, the paint is immaculate; the best I've ever seen, but I'm not an expert.
I looked at this car a couple months ago and he still has it, ready to deal a little more. At that time, I spoke to the president of the local corvette club, but didn't get a lot of help there. Obviously it would be great to take someone knowledgeable with me to look at it again, but I don't think that's going to happen.
Looking for an "ice cream getter". My thought process was to also buy something that wouldn't be constantly depreciating, but either stable or slowly appreciating in value.
Thanks for the help and sorry for the length of this.
I'd go back to that Vette club & find someone who can help you out. It's a good way to get new members right? I would also hope that who ever dumped all of that $$$ into the paint & body did it because it was a solid car. Not always the case but most of the time it is......
http://forums.corvetteforum.com/c3-g...ls+kick+remove
Try searching for "checking for rust" or "remove kick panel" in C3.
Good luck.
Rick B.
http://www.corvetteforum.net/c3/vette73/index.htm
If you haven't yet found a knowledgeable person to go with you to look at the car, may I suggest that you contact Tom Vollrath, from the Mid- Atlantic Chapter of the NCRS. tom vollrath@hotmail.com There are lots of members in Virginia, so he may be able to hook you up with someone familiar with 73s.
You can also call Chuck Berge in HayMarket Va.. 703-754-1960 or 703-629-0206. He knows Corvettes, too.
Regards,
Alan
Regards,
Alan
Good luck!
The history is I wanted a Z3 about 8-10 years ago, but we could not afford the price tag. I opted for a Miata, which was a lot of fun, very reliable, but not a Z3, and certainly not a Vette. Anyhow, I got NOZ34ME on my license plate, started using it on the Miata forum, and others, and it's sort of stuck.
Does that sound right? $5K for a '73 with beautiful paint?
I need to get back over to look at the car and check out behind the kick panels.
