73 coupe
Old Dec 15, 2008 | 10:02 AM
LayZ's Avatar
LayZ
Default 73 coupe
Hey guys, looks like I will no longer be vette-less soon. I had an 86 and in a few weeks I will be picking up a 73 coupe 4spd. Needs some work but if I pace myself and skimp a bit with used instead of new I can get it running again fairly quick. For some reason it has manual steering and brakes. I would have thought that with the 4spd it would have at least have one power option. So I'm a C3 guy now, how hard is teh vaccum system in these things? I do not think it works since the headlights are in the up position.
Old Dec 15, 2008 | 11:45 AM
Durango_Boy's Avatar
Durango_Boy
Welcome to the C3 section. Make sure you post a lot of pictures of your car...I personally LOVE the '73 and I know the next C3 I buy will be a '73.
The vacuum system really isn't that hard once you get a few vacuum diagrams. One thing I would suggest you get first off is an AIM for that year Vette, and Wilcox the vendor has them on CD, PDF version, and it will show you everything you want to know.
Wilcox also sells about everything you would need when replacing old or worn components. Once you get the car we'll help you trouble shoot the headlights to see what the problem would be.
Old Dec 15, 2008 | 01:29 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
I have heard story of people "wiring" their headlights in the up position because they liked that look better. I have also wondered if that was an urban legend because I have never spoken to a Corvette owner who has said they have done this, nor seen an example of this behavior first hand. Regardless, if I bought a car where the headlights were up in all conditions, the first thing I would check would be to see if there was an auxilliary headlight vacuum switch that was engaged. Probably the second thing I would check would be to see if the system had been purposefully disabled in some way.
Old Dec 15, 2008 | 01:50 PM
rydoc's Avatar
rydoc
Welcome and congrats on the "73"
I also love 73`s,... Durango Boy has the answer AIM
We will need to see pics
Rod
Love the Vette
Old Dec 15, 2008 | 02:04 PM
Durango_Boy
Nothing really to wire, and anyone can lock their headlights in an UP position if the vacuum system isn't working but it's best to find the source of the problem, which may be a vacuum leak, which will also affect the performance and drivability of the car.
Old Dec 15, 2008 | 03:39 PM
Derrick Reynolds
I agree for the most part. If there was no vacuum switch engaged and the lights were not physically prevented from going down, I would move on to checking the "close side" of the vacuum loop. I am sure I am making up terms here, but I can only picture the system in my head, not the vacuum schematic to know what the parts are called.
Old Dec 15, 2008 | 05:23 PM
ABOB5's Avatar
ABOB5
I had this problem with my 73 and the valves were bad congrats on getting a C3
Old Dec 15, 2008 | 05:42 PM
Alan 71's Avatar
Alan 71
Hi LZ,
Congratulations on your new, old car.
My 71, 4-speed car, doesn't have power steering or brakes either. I see very few cars without one or the other or both.
You're in for some BIG fun!
Regards,
Alan
Old Dec 22, 2008 | 01:02 PM
ahanasky's Avatar
ahanasky
Cruising
I am new to all tthis but my 73 has a switch under the steering column to work the light doors without turning on the switch at the dash.
Old Dec 22, 2008 | 08:07 PM
RMS73's Avatar
RMS73
Take a look at:
http://www.corvette-101.com/vacuum.htm
for the vaccum issues. There are other sites, but this ones a good start.
BTW welcome tot he 73 World.
I keep a database/registry on 73's. If you want send me the VIN, options and trim tag info for entry.
Roger
Old Dec 26, 2008 | 10:53 PM
C7GrandSport's Avatar
C7GrandSport
Congratulations, you got the best year.
Where are the pics?
To 73 coupe
