Changing vinyl interior colors
Old Dec 15, 2008 | 07:54 PM
skipinhouston's Avatar
skipinhouston
Default Changing vinyl interior colors
Changing interior vinyl trim color.
I understand the drill and products and how to use them, but I have another question.
Is it feasible to change from the ('73) dark blue to a lighter color like parchment or tan with the dyes available.
I'll have to get some new door panels and seat covers anyway, but I don't want to have to buy new dash pieces if I don't have to.
I had one Corvette store here in Houston tell me it was a no-brainer, but I wanted to ask the group before I dive in to make a change like this.
Thanks in advance.
Skip in Houston
Old Dec 15, 2008 | 08:09 PM
dannyman's Avatar
dannyman
Short answer, Yes.
Just make sure you clean and prep parts properly before dyeing.
Old Dec 15, 2008 | 09:36 PM
'75's Avatar
'75
Originally Posted by dannyman
Short answer, Yes.
I took a black piece and dyed it med saddle, you cant tell it from the original pieces.
Old Dec 15, 2008 | 11:46 PM
7T1vette's Avatar
7T1vette
And buy your vinyl dye from a reputable [professional] auto paint supply store...not the local auto parts place or the internet.
Old Dec 16, 2008 | 01:19 AM
mg267's Avatar
mg267
could you turn a black into a white/ivory if properly done?
Old Dec 16, 2008 | 03:32 AM
56early's Avatar
56early
Preperation is the key factor for dyeing interior components. They have to be absolutely free of all dirt and oils. Sems makes a great Vinyl Prep . I've used it many times with great success. Items such as the console arm rest used from 77-82 came from GM in black only and had to be dyed interior color. High wear areas will in time wear out , such as seats and door arm rests.
Old Dec 16, 2008 | 01:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 7T1vette
...And buy your vinyl dye from a reputable [professional] auto paint supply store...
SEM Automotive Interior Dye. Excellent stuff.
Old Dec 16, 2008 | 03:12 PM
1982CorvetteDude's Avatar
1982CorvetteDude
We have a local paint supply store that sells sem color coat. It's the same stuff you would be buying from Corvette America if you get it in the can, they just re-label it.
I can walk in that store and buy any color all day long
Here is a chart for comparison of the colors.
Old Dec 17, 2008 | 12:29 AM
7T1vette's Avatar
7T1vette
Is SEM "Color Coat" dye or paint? I agree that it is the same stuff sold in aftermarket places, but descriptions of the results on this Forum lead me to believe that it is a paint product. Where does the color chart say that it is vinyl dye?
Old Dec 17, 2008 | 08:15 AM
1982CorvetteDude
This is a subject I don't agree with a lot of people. Personally I feel there is no such thing as a vinyl "dye". All of it is basically a paint with a flex agent built in. The layers can wear down over time and need a re-coat.
That stuff does fuse better with vinyl and plastic than a can of Krylon because it's designed to fuse with those materials.
Sem color coat, in my opinion is the best stuff you can get on the market. They just don't call it dye, because that's not what it does.
The stuff at the auto parts store that's called vinyl dye does the exact same thing as sem's color coat.
If anyone can show me a can of vinyl dye that can physically change the color of a piece of plastic or vinyl and not just cover it.....I'll change my opinion.
Old Dec 17, 2008 | 10:03 AM
7T1vette's Avatar
7T1vette
I don't really care to change your opinion....we all have the right to one, anyway. All I will say is that 'stuff' specifically sold and labeled as "vinyl dye" is physically very different than paint, it covers differently than paint, it is more difficult to chip or peel off of plastic parts than paint, it doesn't fill grain like paint, it dries considerably faster than paint and doesn't really have a 'cure' period; and you can dye...and re-dye...and re-dye all you want and never lose the original surface appearance or have to worry about covering dark with light, etc. Now, if you choose to call them both PAINT, have at it. Just don't confuse everyone else with your need to label it something it isn't.
Old Dec 17, 2008 | 10:04 AM
1982CorvetteDude
Old Dec 17, 2008 | 10:10 AM
1982CorvetteDude
It's still a paint.......not a dye That includes ANYTHING labeled "dye"..it's a misconception.
Old Dec 17, 2008 | 10:17 AM
7T1vette's Avatar
7T1vette
There you go again....confusing the 'masses' that don't know one way from the other....
Old Dec 17, 2008 | 10:25 AM
Easy Mike's Avatar
Easy Mike
...that 'stuff' specifically sold and labeled as "vinyl dye" is physically very different than paint, it covers differently than paint, it is more difficult to chip or peel off of plastic parts than paint, it doesn't fill grain like paint, it dries considerably faster than paint and doesn't really have a 'cure' period; and you can dye...and re-dye...and re-dye all you want and never lose the original surface appearance or have to worry about covering dark with light, etc. ...
Old Dec 17, 2008 | 10:41 AM
7T1vette's Avatar
7T1vette
Here is how Wikipedia defines the difference:
Vinyl dye is a product often marketed for use in recoloring vinyl upholstery in vehicles. It is also useful in recoloring soft plastics. Unlike conventional paint, vinyl dye seeps into the surface it is applied to, resulting in a color that will not peel or chip.
Those who perform 'casemods' on their computers favor vinyl dye for the professional appearance it lends to dyed plastic pieces. Raised print, such as brand names and volume increment markings on drive faceplates, are not masked by vinyl dye as they would be by conventional paints.
Only bare plastic and vinyl surfaces may be dyed. Painted surfaces prevent the dye from reaching the plastic, paint having filled in the microscopic holes the dye would normally occupy.
Dyed surfaces may even be re-dyed another color.
So, for those who wish to PAINT their interior parts....BEWARE!!!
Old Dec 17, 2008 | 11:19 AM
7T1vette's Avatar
7T1vette
Lastly, here is a website that describes both paints and dyes. If there weren't any difference between paint and dye, I doubt that this site would mention both for all kinds of applications. Note particularly it mentions both vinly dye and vinyl paint.
www.dyeandpaint.com
To Changing vinyl interior colors
Old Dec 17, 2008 | 11:34 AM
JDemp's Avatar
JDemp
I used Mid-America's "dye" and it worked well but I was not changing the color. You will need at least 3 cans for the job maybe alot more if you are changing colors!
I just washed the parts and primed them with a light gray also sold by Mid-America. Turned out very nice.
My interior is light smoke "gray" I wish it was a dark color to hide some of the wear etc. You might want to look a someone's unrestored light interior before switching colors. The darker colors just hold up better over time.
Old Dec 17, 2008 | 12:27 PM
1982CorvetteDude
Default Corvette America "Dye" versus Sem Color Coat..same thing
See the label peeking underneath this?
Bottom of cans......Landau Black
Old Dec 17, 2008 | 01:31 PM
1982CorvetteDude
Link
SEM COLOR COAT is formulated to match, restore or change color on most vinyl surfaces, flexible and rigid plastics, carpet and velour. COLOR COAT is fade resistant, flexible and is a permanent coating. COLOR COAT is not a dye
Currently available in over 50 colors including 3 blacks, 3 clears and a selection of OEM automotive, bus and marine colors.
* What Is It?....Color Coat is a solvent base, elastomeric product formulated for coating all of the substrates listed above.
* How Is It Applied?....Color Coat is designed for spray only, and is available in aerosol cans only.
* How About Carpets?....Color Coat is formulated to enhance and restore faded carpet color, not to do a drastic color change.
* What About Plastics?....Color Coat is formulated to refinish flexible plastics, such as dashes, consoles, kick pads, etc., most semi-rigid and rigid plastics.
