Need Help
here is the ad http://baltimore.craigslist.org/ctd/952501138.html
the engine sounds great and it runs... but.... feels like i am towing a truck... does not go even when i floor it. i am new to this and love the car... anyhelp would be greatly appreciated
Now if the converter is screwed and way too loose, the car will drive like a bag of crap, the motor will rev and the car wont go anywhere.
Have you tried leaving in low and shifting up through the gears.or have you gone from a roll and kicked it down into passing gear , hold it to the floor and let it shift up by itself?
My 1980 vette is a complete dog. 190 hp and a 3.08 gear. I am building a 360 HP 350 for it and installing 3.55 gears. That will wake it up.
Is there any chance that there's a brake problem that's causing them to drag? Have you checked to see if they're hot after you drive a little? That would make the car feel like it's dragging it's feet when you're trying to make it go.
Did it do this when you test drove it before buying it?
Good Luck.
Happy New Year!
Regards,
Alan
Good Luck.
Happy New Year!
Regards,
Alan
Welcome to the '73 club. Looks like a sweet car. You must have a wonderful wife.
I don't know if anyone has explained this completely yet but I'll give it a shot. When they talk about a high stall converter, they are talking about the torque converter. It is a round (kinda donut shaped thing) that sits between the engine and transmission. It is what provides the link between the two. When you are sitting at a light, it provides a little slip in the system so that the engine can run at idle but the transmission doesn't move. An original (from the factory) torque converter will "slip" until about 900 rpm or so. Then it "locks up" and provides a connection to the transmission. It's basically the clutch for an automatic transmission.
A high stall torque converter essentially has more "slip" built into it. Depending on what you buy, it may not "lock up" until 2500 rpm or more. This allows the engine to be spinning faster and making more horsepower when it locks up. These are mostly used on high performance and drag racing cars.
I've never driven a car with one of these, but I would think you could check by taking it out on the street and slowly push on the gas. See if there is a point where the power really kicks in. You may have to put one foot on the brake just a little to keep it from rolling forward before you hit the stall speed.
Once the converter locks up, it should run and drive great. It would just be a matter of getting used to the higher stall speed.
Now, if it is still acting strange after 2500 rpm or so, there is a problem.
If it were me, I would change it back to an original type converter. It will be much more drivable for day to day cruising around.
If you can still talk to the previous owner, give him a call and see what the stall speed was supposed to be. I'd also ask him when was the last time he changed spark plugs, plug wires, distributor cap and rotor, and fuel filter. Also the points if it still has them. A good tune up can do wonders for these old cars.
Good luck and ask questions. We will help if we can.
Here is a link to a place selling high stall converters if you want to see what they look like.
http://store.summitracing.com/egnsea...115+4294904018
