Distributor cable
Old Dec 28, 2008 | 06:14 PM
69FASTFUN's Avatar
69FASTFUN
Default Distributor cable
Does anybody know what the correct length for the tach drive cable is?I checked the gear and it looks OK and the Tach itself is not in a bind. What else could cause the cable to break, I changed it about 9 months ago.
Old Dec 28, 2008 | 08:12 PM
BigBlockTank's Avatar
BigBlockTank
Some vendors sell an attachment that lessens the big angle that the cable is in, in some cases. I am lucky and don't need one with my MSD tach drive distributor. And I'm gonna think that you've lubed the cable itself........
Old Dec 28, 2008 | 08:34 PM
69FASTFUN's Avatar
69FASTFUN
What type of lube works the best?
Old Dec 28, 2008 | 11:33 PM
...Roger...'s Avatar
...Roger...
If the small tach gears are binding it can break the cable.
Old Dec 29, 2008 | 12:14 AM
Ironcross's Avatar
Ironcross
There is two lengths, I believe the 69 and after is the 19 inch or longer than the lone wolf again 1968 at 18.5 inches. I used wheel bearing grease and loaded the housing with it.
Old Dec 29, 2008 | 11:46 AM
...Roger...
I've used both wheel bearing grease and the thin AC grease for cables but never noticed much difference.I've also used a moly grease.
Oh and I just thought; on a speedo cable I used a stringing grease one time for one that the cable rattled. The small tran gear was new along with the sleeve.In about 2 days the guy called and said the speedo had quit. That stringing grease had so much constant resistance it took all the teeth off the small plastic gear.Glad I didnt try that on a Tach cable,that would have been an expensive comback.
Old Dec 29, 2008 | 06:46 PM
Alan 71's Avatar
Alan 71
Hi69,
My parts book lists both 19" and 20 1/2" for 1968. It lists another part # for 69-72... but NO LENGTH!?!
Paragon lists a 23" cable but says to check the length of your present one before ordering.
Mr.Wilcox if you please.....
Happy New Year
Regards,
Alan
Old Dec 29, 2008 | 06:55 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I ordered one recently but it is way too long.
Old Dec 31, 2008 | 12:50 AM
FB007's Avatar
FB007
As long as you clock it parallel to the firewall, it doesn't need an angle drive, no matter who made it.
Old Dec 31, 2008 | 11:38 AM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
the only caveat here is if you use the stock ignition shielding, if you do, the vaccum canister wont allow this the the use of one of two types adaptors to easy the stress on the cable from the bend
cheers
Old Dec 31, 2008 | 01:18 PM
...Roger...
cheers
Why wouldnt the stock shielding allow this?Put the nipple behind the bracket.Is the nipple what you were referring to?
Old Dec 31, 2008 | 02:54 PM
sweethence's Avatar
sweethence
allow me to clarify,
with the stock early ignition shielding, you need the nipple or the other adaptor to keep the keep the cable from making the the sharp bend.
What i was attempting to say was you cant just simply rotate the distributor to allow the cable to run straighter with the ealrly shielding in place. there is not enough room inside the shielding with the position of the cross gear to rotate without the vaccum canister coming in contact with the shielding and still having room to set and adjust the timing
cheers
happy new year
tim
To Distributor cable
