Needed Tools
Old Dec 31, 2008 | 08:42 PM
jaycall88's Avatar
jaycall88
Default Needed Tools
Hmm, so far as I work on my c3 corvette, i find myself buying tools as I need them for each job i do.
I was wondering is there a list of basic tools that I should have to work on these cars?
Old Dec 31, 2008 | 08:50 PM
wnmech's Avatar
wnmech
In my opinion thats A hard question to answer it is going to depend on how much you are planning on doing. If its just basic keep running maintenance I would like to have a 1/4in socket set with extentions and a 3/8th socket set and a set of combo wrenches and pliers and vice grips and assortment of screwdrivers. that would be A good starter tools.
Old Dec 31, 2008 | 11:05 PM
427-390's Avatar
427-390
You can get anything from a good to superb starter set of Craftsman hand tools at Sears and add to the set as you move along. Depending on your skill level, consider 3/8 and 3/4" torque wrenches, various vice grips in different sizes, a BFG, (Big Effin' Hammer) a 5lb one will do, various sizes and types of pliers including channel locks, diagonal side cutters, commonly called "dikes" by the non-PC crowd , wire stripper/crimper, feeler gauge, and a bench vise if you have a bench to mount it too. That should get you going. Others can join in any time.
Old Dec 31, 2008 | 11:50 PM
Ironcross's Avatar
Ironcross
Pullers are specialized tools and should be purchased with caution. Only quality names and there several types of them. Snap on, Mac, and even Sears. No import stuff on pullers. And also a good vice.
Old Jan 1, 2009 | 02:48 AM
Carl Granquist's Avatar
Carl Granquist
Default more tools
The above all have good suggestions and you'll probably see that it's an "evolution" in your workshop. Years ago mine started with the basics but has grown. Lately most of the specialized stuff has come from ideas here on the Forum.
I built a nice set of wood ramps, so a creeper is essential for me for a visual on the underside plus ease of work access. I also had some electrical questions/issues so a multimeter came in handy (found a good one on sale). My timing light is probably more than I need but was a Christmas gift from my wife, so what can I say? (INNOVA #5568). Heat is a good information source, and I picked up a high temperature infraRed thermometer (on sale from Sears a few months ago) for headers & exhaust ports/thermostat housing/etc. Fun and easy to use.
I'll admit that my Corvette is a hobby and a retirement project for me, so there's no rush and I want to prolong the "fun factor." My next big step will be an air compressor for "pro" type shop air-power tools and accessories.
jaycall88 - just pick them up as you need them, but get good ones!
Old Jan 1, 2009 | 03:11 AM
jaycall88's Avatar
jaycall88
o ok cool!
hows this starter tool set?
http://www.sears.com/shc/s/p_10153_1...000P?adCell=A3
Old Jan 1, 2009 | 04:57 AM
Bob Onit's Avatar
Bob Onit
Originally Posted by jaycall88
o ok cool!
Not bad for a starter set (says out of stock by the way). It's shy on extensions for the ratchet wrenches but extensions are one item that you can buy separate at lower quality because there's really not much that can go wrong with them.
If you are going to be working on a C3, sooner or later you're definitely going to need a vacuum gauge.
Since a Mighty Vac kit has a vacuum gauge built in to it it's a great tool to have.
It's a vacuum gauge/pump in one and it's invaluable for diagnostics, brake bleeding, tuning ect:
The plastic pumps are fine for occasional use and are about $30 or so.
Old Jan 1, 2009 | 05:07 AM
RunningMan373's Avatar
RunningMan373
A basic Sears tool set, a 150ft/lb Torque wrench, a breaker bar, a second set of Sockets the same size as the set and a second ratchet, then the specialized stuff as you need it, best way to build up a good collection. I have tools from 20 years ago in my tool box. Other then that, 2 sets of good jack stands and 3 floor jacks, 2 can be the cheap type (20 bucks each?)
Looking at the set listed, you'll also need at least one and better two FULL wrench sets,, 4 pieces just ain't gonna cut it. C.
Old Jan 1, 2009 | 09:41 AM
Alan 71's Avatar
Alan 71
If you do any interior work, especially carpet work, it's a good idea to have the kind of scissors that has a dial you can set at CUT and UNCUT.
Happy New Year
Regards,
Alan
Old Jan 1, 2009 | 11:33 AM
Theiskell's Avatar
Theiskell
The guys have given you good advice. The only thing I can add is...every time i go to sears or lowes I try to by a tool. Even if you don't need it now you will in the future
Old Jan 1, 2009 | 11:49 AM
my 76 ray's Avatar
my 76 ray
I haven't seen anyone mention a 1/2 inch socket set and ratchet. The older I get the more I need the extra leverage to break the nuts loose. Also the breaker bar for the 1/2 inch is longer (more leverage).
You won't need many or maybe no metric sockets for the Vette, but if you get into doing repairs on any newer car you'll need them. That said, I would buy the socket set with the most versatility (metric, standard, in both deep and shallow sockets for each of the 1/4, 3/8 and 1/2 inch drives).
Wrenches, screwdrivers, pliers etc are cheaper if you buy sets. Sears has sales on them all the time. Again, would get the most versatile set I could afford. You'll use basic hand tools for almost every job and having the right tool makes it a lot easier.
For everything else, I buy them as I need them. Just consider it a part of the cost of the job. You'll still save money over paying to have the job done and you get to keep the tool for the next time.
Old Jan 1, 2009 | 12:00 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Don't ever buy cheap tools as they are expensive. Any tool kit must have a quality floor jack. I have 3, but that is over many years. Jack stands, and use them. If there is any room in your budget, Snap-On tools feel real good in a mechanics hand. Oh yeah, band-aids... Pretty soon you will need that lift.
Old Jan 1, 2009 | 12:02 PM
Paul L's Avatar
Paul L
This is an inexpensive set that can help prevent a lot of grief. We all know that screws, nuts, bolts, valve spring keepers, etc. can take on a life of their own, often flying off into places that are inaccessible to human beings. The rod is telescoping with a swivel magnet end/probe. When you do capture that little critter you can prevent further flights by placing it in the stainless steel magnetic dish.
Old Jan 1, 2009 | 12:55 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
When I was 15 my parents bought me a nice Craftsman set with standard and metric tools. Since then, I have bought tools as I need them. I also consider it part of the cost of the job. It is still cheaper to buy the tools and do the job yourself, then to have someone else do it.
I also inherited my grandfathers tools. He was a mechanic for 35+ years and had very nice stuff. Then when my Dad retired, he gave me his work tools. So now I have 3 sets of many things, but you can never have too many tools.
I also use lots of jack stands. I have 10 of them and will put them all over the place. I knew a guy that died when his car fell on him so I don't take any chances.
Old Jan 1, 2009 | 01:20 PM
classicvettefan's Avatar
classicvettefan
Default Needed tools
Depending on the year of your car you will need Metric as well as SAE for your socket sets and boxed/open end wrenches.
The C3's built around late 70's and into the 80's have a mixture of both.
I have an 80 and this is the voice of experience.
Old Jan 1, 2009 | 01:24 PM
Bonedaddy's Avatar
Bonedaddy
A set of reversible ratcheting gear wrenches.....absolutely indespensible! They'll reach those hard-to see and reach places. Craftsman has 'em at your local Sears. Oh, and an air compressor + air tools will spare you time and skin. Plus a beer cooler.....to sit on and store barley/hop formula.
Cheers!
Old Jan 1, 2009 | 02:02 PM
Jeff_Keryk's Avatar
Jeff_Keryk
He who dies with the most tools wins.
To Needed Tools
Old Jan 1, 2009 | 04:02 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Tools pay for themselves........
Old Jan 1, 2009 | 07:07 PM
stock76's Avatar
stock76
The Mity Vac is a very useful tool for troubleshooting and tuning but not so good for bleeding C-3 brakes. Get a Motive brake bleeder for that job and save yourself some grief. I have both of these tools and they are invaluable for working on C-3s. the Mity Vac is really handy when troubleshooting vacuum leaks and problems.
Old Jan 1, 2009 | 07:14 PM
Red70vette's Avatar
Red70vette
Buy them as you need them. Also consider renting tools that are specialized for one job. It does not pay to buy a tool you will only use once in a couple of years or perhaps never again. The fact that you do not have tools now tells me that you are new to this game. Take your time and buy them as you go. You may not enjoy working with tools and end up sending out your work to someone else thereby negating the need for tools.
