how do you find the orig. build sheets for your vehicle? When I had my GTO I had to go through PHS documentation is there something similar with corvettes?
No. Nothing similar for Corvettes. 68-72 C3s had a copy of the Corvette build order glued to the top of the fuel tank, giving rise to the term "tank sticker." These documents were only meant to be aids to assembly line workers and were never meant to be permanently affixed to the car. Some owners have been fortunate enough to find them, others have not. It is also possible to find part of a build sheet with the rest of it missing, or to be a fragment of a document which cannot be read.
Typical. The tank sticker is there, but it's illegible after years of accumulated road gook.
Beginning in 1973, the format of the build sheet changed and they began to be taped to the front of the fuel tank.
The single best source of original documentation for a C3 should come with the car at time of sale.
For some of the 77-81 models, GM contracted with a company called Allied-Vaughn to microfiche copies of the original dealer invoices. These are available from Allied-Vaughn. Order copies for most of the Bowling Green built C3s are available from the National Corvette Museum. In either situation, information for a specific Corvette may, or may not, be available.
Many of the sheets I see have the upper left corner torn off with a straight edge. I wonder why?
Regards,
Alan
I hadn't thought about it until you pointed this out, but mine also has the top left corner torn off with a straight edge.
Only photo I have with gamma adjusted to better read the writing.
...Many of the sheets I see have the upper left corner torn off...I wonder why?...
They were a seven page carboned form. Most folks held them by the upper left corners and burst the separate pages at the time they we sent to the individual stations.
Only the last two pages had the VIN info on them, but you could take the bundle, flip to the last page, get the VIN, subtract 500, and pencil in a job number on the first copy (early method) or jot down the last three digits of the VIN (later method). The 209 on Razman's sticker is a perfect example. Ditto for the 89 on yours.
Razman: out of curisoity, does your VIN end with 709 or 209?
Alan: what are the last three digits of your VIN?
well thats no good wanted to verify some things., I have a neighbor that had a 68 as well and told me that the car orig. had a 427 according the the heavy duty springs that are in it. It currently has a350 in it. It does however still have the M22 rock crusher transmission.
how do I go about verifying the engine that was in there and if i do find a 427 that was built in that year/time frame would that be considered a numbers matching car then?
The last part of your question has the most straight forward answer. Most people use the NCRS guide that a car's parts should not proceed it's build date by more than 6 months.
Determining if a car WAS a BIG BLOCK car is a lot more of a slippery slope.
Regards,
Alan
...how do I go about verifying the engine that was in there...
Your only hope is original documentation which came with the car (dealer invoice, window sticker, POP, etc.) or a legible tank sticker.
...if i do find a 427 that was built in that year/time frame would that be considered a numbers matching car then...
Some say yes; some say no. A replacement engine with the correct part numbers and date codes would be correct for judging, but it will not be numbers matching.
