Ignition Cylinder replacement
Old Jan 7, 2009 | 01:30 PM
TJ81's Avatar
TJ81
Navigator
Default Ignition Cylinder replacement
I'm working on an 1981. I bought a matched set of locks/ignition and wondering if anybody has any advise on how to change out the Ignition cylinder? Thanks
Old Jan 7, 2009 | 02:04 PM
Solid LT1's Avatar
Solid LT1
Jim Shea has blessed us with some of the knowledge aquirred while he spent years at GM here is a link: http://jimshea.corvettefaq.com/?page_id=4
Old Jan 7, 2009 | 03:12 PM
82Red's Avatar
82Red
I too will be attempting replace my ignition cylinder on my 82 this weekend.
Old Jan 7, 2009 | 04:34 PM
udornf4's Avatar
udornf4
Saw a "pre-69 procedure" for removing the switch, but that was it???
Old Jan 7, 2009 | 06:40 PM
TJ81's Avatar
TJ81
Navigator
I went to the jimshea site and I also seen and read the "pre-69" but not sure if it would be the same for an 81?
Old Jan 7, 2009 | 07:41 PM
Glassbowtie77's Avatar
Glassbowtie77
I did mine this past summer using Jim Shea's procedure it was very straight forward and made replacement go relatively easy.
Old Jan 7, 2009 | 11:27 PM
TJ81's Avatar
TJ81
Navigator
Thanks for all the input!
Old Jan 8, 2009 | 12:14 AM
Jim Shea's Avatar
Jim Shea
Pre 1969 the lock cylinder and ignition switch were one unit and were mounted in the instrument panel. You can remove the lock cylinder with the ignition key and a paperclip. From 1969 forward the lock cylinder was in the steering column head and the ignition switch was down under the dash on top of the steering column jacket. The lock cylinder now can only be removed by disassembly of the steering column head.
To replace the lock cylinder you will need to remove the steering wheel, steering wheel hub, locking plate, and pull the turn signal switch out from the column head. After 1978 the lock cylinder was retained in the column head with a screw. You will need to remove the screw and the lock cylinder will slide right out.
Complete instructions are at the www.corvettefaq.com websight.
Jim
Old Jan 8, 2009 | 10:59 AM
TJ81's Avatar
TJ81
Navigator
Jim, Thanks for the information it is really appreciated.
To Ignition Cylinder replacement
