Header Bar Question
Old Jan 9, 2009 | 10:04 AM
at3erdbase's Avatar
at3erdbase
Default Header Bar Question
I am putting a header bar my 68-72
I have the bonding strip and rivets .
I have a later header bar from post 72.
Are they the same size? I know they need to be drilled for rivets.
be good
Old Jan 9, 2009 | 02:33 PM
Manuel Azevedo's Avatar
Manuel Azevedo
I have the bonding strip and rivets.
be good
The later bars did not use a bonding strip. They just bonded the bar to the nose. So really you do not need to use the bonding strip at all. Had plenty of adjustment of the head light without the bonding strip on my 68, The way I see itm the factory seen it was not needed in the later cars and I like the idea of less problems with less bonding.
Old Jan 9, 2009 | 04:52 PM
dennis's Avatar
dennis
be good
I don't understand what year you have, and what year the doner bar is from. There is a difference in how the headlight relays mount to the header bar. But as suggetsed with the structural adhesives available today, having to rivet a metal part to fiberglass in order to have it adhere to fiberglass is a thing of the past.
Old Jan 10, 2009 | 12:52 PM
at3erdbase's Avatar
at3erdbase
I agree with you guys. It is a thing of the past.
My question is simple.
I have a 68-72 that came with a bonding strip that riveted to the header then was glued on to the surround.
1. I have the header bonding strip from a 68- 72 as my car is a 68
2. I have a 73-82 type header bar
Now I know I can just glue it to the surround.
My question is... Is there a difference in the size of the header bar on the 68-72 compared to the later models
As I see it, the only difference is needing to drill holes
be good
To Header Bar Question
