Build Sheets
Old Jan 11, 2009 | 06:48 PM
Alberni Redneck's Avatar
Alberni Redneck
Cruising
Default Build Sheets
Hi Guys, I understand that the original build sheet from production is a sticker on the drivers side of the gas tank. My question is: Does GM keep records of these and if so, who would I write to to get a copy of the original build sheet?I had a peek through from the tailight I removed today, and could definately see a wrinkled up piece of paper but way out of reach, and not enough space to get my camera up there to take a pic of it.
Thanx,
Glen.
Old Jan 11, 2009 | 07:28 PM
Vampyre's Avatar
Vampyre
Not sure the year you need, but can find them here.
https://store.corvettemuseum.com/ser...buildsheet.asp
Old Jan 11, 2009 | 07:32 PM
Vette79C3's Avatar
Vette79C3
Thanx,
Glen.
Some 79-81 owners may be able to obtain a copy of the dealer invoice for their cars from Allied-Vaughn following the links here. http://www.corvetteactioncenter.com/...x.php?cmd=area
Most owners of Bowling Green built cars can obtain copies of their build sheets from the NCM. Records for the earlier cars do not exist.
Old Jan 12, 2009 | 09:49 AM
1nicecorvette's Avatar
1nicecorvette
the best thing to do is drop the tank, if you dont want to go that far you can lay on your back and reach up over the top ofthe tank and remove it. remember it is glued on usually through the center and sometimes glued pretty well so be easy with it.
build sheets arent available for the 78 but the dealer invoice is. i removed my 79 build sheet by reaching up and over. i then redrew it with all original information etc from another build sheet i found online, as well as my original delaer invoice (link above) this way i always have a 100% new copy of it as it was the very first day. my original sheet is framed and put away but i too made a scanned image of that one incase it deteriorates away in time.
Old Jan 12, 2009 | 04:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I understand that the original build sheet from production is a sticker on the drivers side of the gas tank....
1968-72 only. For 73 and later models, it's usually taped to the tank.
...Does GM keep records of these...
No. the records are long gone.
...who would I write to to get a copy of the original build sheet?...
You cannot get a copy of a build sheet/tank sticker. 77-81 owners might be able to obtain a copy of their original dealer invoice from Allied-Vaughn. http://www.corvetteactioncenter.com/...x.php?cmd=area
For owners of Bowling Green built cars, the National Corvette Museum may have a copy of the build sheet. https://store.corvettemuseum.com/ser...buildsheet.asp
The last resort would be dropping your tank to see what's there. Unforunately, what's there may be incomplete or illegible.
Good luck.
Old Jan 12, 2009 | 07:03 PM
Alberni Redneck
Cruising
Default Thank You
Thank you one and all for your replies, I may have lucked out as my 78 is a Canadian Sold model, and there restoration kit includes an Options list (build sheet) specific for my car.
Thanks again,
Glen.
To Build Sheets
