Does anyone repro the cargo tie down straps?
Old Jan 15, 2009 | 06:39 PM
red70stingray's Avatar
red70stingray
Default Does anyone repro the cargo tie down straps?
anyone reprducing them along with all the hardwear?
Thanks!!!
Old Jan 15, 2009 | 07:49 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
No one is making them, but I should have a good used one. Depends on what color you need. Give Norm or Tommy a call tomorrow if you want and they will look.
800-588-3883
Willcox Inc.
Old Jan 15, 2009 | 08:56 PM
7T1vette's Avatar
7T1vette
If you need to change the color, just re-dye them with the correct color of vinyl dye [after you thoroughly clean and dry them, of course].
Old Jan 15, 2009 | 11:46 PM
0Willcox Corvette
Former Vendor
7T1vette
The roof panel straps are made of a Nylon type material (Similar to the seat belt webbing) and will not take the painted dye very well. They will dye, but they become a little hard from the spray dye.
An old trick on this type of material is to use RIT dye and boil them in water. I’ve done faded seat belts this way and they have worked out great! You basically mix up the color you want and test it. Once you have the color heat the dye and insert the belt. If you are doing seat belts with retractors you have to channel lock the belt in the outward position and keep the retractor out of the dye. The tiny area that is not in the dye will not show up once installed.
Willcox
Old Jan 16, 2009 | 12:07 AM
milo30's Avatar
milo30
what color do you need?
Old Jan 16, 2009 | 11:41 AM
7T1vette's Avatar
7T1vette
Willcox Corvette:
Vinyl dye will not make the nylon belts stiff...unless you use a spray paint that the manufacturer has [incorrectly] labeled as "dye". I have become suspicious that the spray cans of 'dye' sold by the aftermarket companies are really paint, as there have been many comments by CF users as to how such products behave...and they are not consistent with my experience in using SEM vinyl dye products (liquid vinyl dye in cans and sold by pro auto paint supply stores). It is interesting to note that SEM also sells another coloring product, which is basically a paint [but they do not label it as a dye].
Several CF members have used real vinyl dye to re-colore seat belts with no indication of the resulting belts becoming 'stiff' after the repair. So, I suspect the difference is due to the product being used. I thought this info might be of interest to you and CF users.
7T1vette
Old Jan 16, 2009 | 07:36 PM
0Willcox Corvette
Former Vendor
Originally Posted by 7T1vette
Willcox Corvette:
7T1vette
I agree with you 100 percent. I guess I'm used to people using the other stuff and thinking it would dye the vinyl web. It won't, it makes the material stiff and hard!
Real vinyl dye will work, and the Rit trick works even better it's a pain to use. The issue with the Rit trick is if it's not black or a common color you have to play with it for hours to get the right color.
Willcox
Old Jan 16, 2009 | 09:38 PM
7T1vette's Avatar
7T1vette
You can get vinyl dye mixed to the interior color code of your car and it will match (your original stuff might have faded...but the new dye is the right color). And it will easily cover any color with a couple of light coast..even tan over black. It is "the right stuff"!
Old Jan 16, 2009 | 09:54 PM
Earthquake Driver's Avatar
Earthquake Driver
From: I buy all my days at the same place where the girl sells her nights
I had one done for my 70 by "Ssnake Oyl". I sent them the hardware that I got used and they did the rewebbing to my interior color, in my case bright blue.
http://www.ssnake-oyl.com/
Old Jan 16, 2009 | 10:45 PM
GD70's Avatar
GD70
Where can I buy Rit? I want to freshen up my sun faded black carpets and was told this will work perfectly.
Glenn
Old Jan 17, 2009 | 07:28 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
To buy Rit....any fabric store, grocery store or Wally-Mart.
Old Jan 17, 2009 | 11:10 AM
7T1vette's Avatar
7T1vette
Dude! I can't imagine going to the trouble removing an old carpet and choosing to [fabric] dye it, when you could just replace it with new for a bit more money. You'll go to all that trouble just to get a bit more color? Sounds like a lot of work for little gain. You are going to be disassembling most of the interior. Why not just put in new carpet plus clean and re-dye the interior parts? Then it will look like new...
Old Jan 18, 2009 | 09:14 PM
68/70Vette's Avatar
68/70Vette
I bought a bunch of the cargo straps on ebay. Cut off the best metal fittings from my collection and sent them to Snake-Oyl. They rechromed one set of metal fittings - the other set was NOS and didn't need rechroming.
When buying ebay straps keep in mind that the 68, 69 and 70 cars had two seperate straps; "II". Later cars had a "Y" single strap. I kinda think that the "II" strap metal fittings are different that the "Y" strap fittings. Not sure now.
Old Jan 18, 2009 | 11:09 PM
red70stingray
anyone have a picture of how a 68-70 looks installed?
Old Jan 19, 2009 | 01:26 PM
GD70's Avatar
GD70
Not hi-jacking this thread, sust responding to the statement.
I assume you referring to me. The carpet is in very good condition wear wise. Just a bit sun bleached to a brownish color in some areas. To me, it's much easier to touch up the existing carpet then pulling it out. If it was worn with holes etc... that would be different.
To Does anyone repro the cargo tie down straps?
