sand blasting question?
Old Jan 17, 2009 | 12:56 AM
1976 corvette's Avatar
1976 corvette
Default sand blasting question?
I have stripped the whole car down to the chassis so now it is time to same blast. Now I am using two compressors linked together equaling 35 gallons because buying a new one isn't in my budget. When I use my sand blaster, it continuously gets clogged either at the top or bottom of the hose and some times in the bit. Let’s just say I worked for an hour the other day and only got an area 1 foot wide by 3 inches tall. Is there any trick, techniques, or advise you guys have to help me with this restoration step.
Thanks,
Kevin
Old Jan 17, 2009 | 01:11 AM
noonie's Avatar
noonie
Tank size has little to do with it. You need psi and cfm.
Depending on the nozzle size and grit used, it could be as much as 20cfm@ 90 psi.
Try the smallest nozzle you can.
Also sounds like you may have moisture in the media. Use good filters or moisture traps.
Old Jan 17, 2009 | 01:13 AM
razman's Avatar
razman
i've restored many cars......my tip to you is this: pay someone to blast the frame and larger pieces. i have a blasting cabinet and a pot i use outdoors for medium size pieces, but when it comes to frames, a-arms etc. i have a guy with a commerial blasting unit come over and do it. it only costs a couple hundred bucks or less, and he is done in a fraction of the time that it would take me, the quality of the blasting is much better, not to mention tons of sand that i would have to go through!
Old Jan 17, 2009 | 02:48 AM
Z51JEFF's Avatar
Z51JEFF
And wear a respirator!
Old Jan 17, 2009 | 08:33 AM
dbeall1968's Avatar
dbeall1968
Razman is right. A real unit uses 100+ cfm, and can do a car frame in a hour or so. The time, aggravation, and the mess is not worth the buck fifty you could pay someone to do it. Be ready with your primer- sandblasted metal will start rusting instantly.
Old Jan 17, 2009 | 11:39 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Yep. I paid someone $80 to blast the frame on my '29 dodge, Good job too.
Of course the other place nearby wanted $250! So shop around...
Oh and I HOPE you are doing the frame and NOT the body.
If you do the body you will end up with swiss cheese and will never ever fill the millions of pin holes
Old Jan 17, 2009 | 05:16 PM
72LS1Vette's Avatar
72LS1Vette
Thanks,
Kevin
It sounds like you are using the same $15.00 Home Depot siphon feed blaster that I used for my frame. Unless you have a water separator in your air line the moisture from the tanks will continually cause the tip to clog up. If the sand isn't completely dry it will clog up in the feed tube. I spent several hours each weekend day for the entire Summer 2 years ago blasting my frame because the process was so slow. If I had to do it again I would certainly take the frame to a pro and get it back in a couple of days.
Rick B.
Old Jan 17, 2009 | 06:49 PM
stinger12's Avatar
stinger12
Send your frame and large parts out to someone to be done. This is coming from someone who sandblasted every part on his own personal car (I even did the frame myself). I had a pressure sand blaster with a 60 gallon compressor and 11 cfm pump at the time. It just isn't worth it. It probably cost me just as much to do it myself than if I would have paid a company to do it (you need to shop around).
Old Jan 19, 2009 | 04:14 PM
mdj21's Avatar
mdj21
Your media is too wet.
You can clear a clog like that by creating back pressure in the system. If you are using a gravity feed pot, ball up a shop towel and hold it over the nozzle opening then pull the trigger for a couple of seconds. This will force air back down the sand supply line which will blow out the clog. If you have a pressurized pot, there should be a lever you switch to create the back pressure for clearing clogs.
Always wear gloves and a respirator while sand blasting. Avoid paper dust masks. They don’t really work that well.
To sand blasting question?
