body mounts
Old Jan 18, 2009 | 11:30 AM
vett 68's Avatar
vett 68
Default body mounts
could any one till me how much of a job it is to change body mounts i've be thinking about doing them but don't know how hard it is to do thanks pete
Old Jan 18, 2009 | 12:13 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I have a terrific article I scanned from one of the popular Vette magazines. PM your email address and I will send it to you.
I used these procedures on my 76 & 78. Worked great.
John
Old Jan 18, 2009 | 04:45 PM
Duke94's Avatar
Duke94
Here's a link to a tech article on how to do it.
http://www.europeancorvette.com/html...eplacement.htm
Old Jan 22, 2009 | 12:06 AM
pepegriffo's Avatar
pepegriffo
I just finished reolacing mounts and #1 and #4 brackets both sides. Brackets were a bear to grind out and reweld in place. If bolts come out easy on 2 and 3 job is a little easier. But if not a lot of hard work. Also cutout driver side # 3 bracket and rewelded in new bracket. You will need to cutout the splash shield for acess to the # 3 bolt and to set the new mounts.
Raised the passenger side about 3" after bolts removed. you will need glue mounts and spacers together to slide into place. you can do this from inside the frame. Driver side will lift about an 1 1/4". enough to side in mounts etc. Mt Bad 79 has some great pic's of his project. Also do a search on "body mounts" you will get a lot of info.
The project is not easy at best but can be done. just think it through.
good luck
To body mounts
