Spark plug Question.... long post
Old Jan 18, 2009 | 02:39 PM
Richard Cooper's Avatar
Richard Cooper
Default Spark plug Question.... long post
Hi,
What is the difference between all the spark plugs? They are just used to ignite the gas in the cylinder. Say I have 3 cans and each one has a little gas in them. I use a wooden match to ignite one can, I use a hand tourch to light another one of them and use a cigarette lighter to light the third one, they all ignite so what is the difference with spark plugs? Don't they jusy put the spark there to ignite the gas. Won't all the gas burn no matter how it's lit? I know the gas is under pressure but does that make any difference. I see spark plugs for $1.59 eack and some for $20.00 each, what is the difference? thanks in advance.
Old Jan 18, 2009 | 03:19 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Too easy. The cheapos run great; the expensives ones don't work. 99 cent Autolites rule! I have not had one fail since the 1960's.
Old Jan 18, 2009 | 03:21 PM
Lester B's Avatar
Lester B
I am no expert by any stretch of the imagination. But I know that the material they are made from has alot t odo with the cost. Some platinum plugs are made to run for 60,000 miles, where as some plugs are made to be changed after say 12,000 miles. I think once you get into high HP engines you need plugs that can stand the temperature. Also I know that when running NOS it is very important that the plugs do not glow and cause pre ignition.
I am sure someone will be able to answer your question more fully than me.
Old Jan 18, 2009 | 04:10 PM
Mike Ward's Avatar
Mike Ward
Price. Nothing to do with making more power. Your analogy is correct.
Old Jan 18, 2009 | 05:11 PM
Paul L's Avatar
Paul L
I really do not know the answer to the question. I find that sticking to the GM recommendation works for me. And AC Delco R45T spark plugs are not expensive.
Old Jan 18, 2009 | 05:44 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yes compression ratio has something to with the how much spark is needed to light the mixture. That said any mild street car will run fine on 99 cent plug. The reason for the higher priced plugs is not for performance ( except if it's a race plug, forced induction etc. ).
For the most part your local parts store will have some higher priced plugs made out of materials that will last longer and therfore you will have to change them less often.
Which helps because of the ridiculous positions they put the plugs in the motors and the orientations of motors themselves in the engine bay that make it near impossible to change the plugs unless you have a trained monkey handy
Old Jan 18, 2009 | 08:37 PM
Erik016's Avatar
Erik016
You should try these and let me know how they are.
http://www.pulstar.com/index.html
$25 per plug at kragens.
Old Jan 18, 2009 | 11:10 PM
Bowerss2's Avatar
Bowerss2
Hi, ...
... I see spark plugs for $1.59 eack and some for $20.00 each, what is the difference? thanks in advance.
the company that charges 20 bucks a pop has 10 times the advertising budget, thats pretty much it. Other than that, they are just snake oil.
I have used champion for ever, but just the cheepoes, work just fine.
any OEM spec plug will work just fine
Old Jan 18, 2009 | 11:14 PM
Bowerss2's Avatar
Bowerss2
i saw a shop put a (stock) C4 on a dyno, they used OEM plugs and wires, then put on some $$ Moroso wires, and those pulse plugs
over 10 pulls there was no difference.
Now if you have a full race plug (not those cheesy pulse plug things) and a race engine, that is another story.
Old Jan 18, 2009 | 11:25 PM
bj1k's Avatar
bj1k
I don't know if it makes a difference in cars driven everyday but I have some cranes with 350 Chevy engines running AC Delco plugs and since they are seldom used long enough to fully warm the engine, they will file the plugs about every six months. I think the heat range of the plug is the only thing that makes a difference on how long the plug will last but go too hot on the heat range on something that is used for racing or used everyday and you could burn a hole in the piston. .
To Spark plug Question.... long post
