Converting to Power Windows..Questions?
Anybody researched this and have FIRST HAND experience?? I think the prices are pretty comparable, either way. The "conversion kit" is around $700. I'm sure the factory doors are already drilled to accommodate either manual or power...
Thanks!
I replaced the doors with power window units,
bought a power window harness from E-bay.
bought a new switch, thats it. 69VETT
Thanks!
the motors came from a similar vintage GM car in a junkyard I frequented, the motors almost never wear out/fail, so what you need do is grab the plug/harness, also and tear down to redo all the grease/bearings.....some of the really early p/w motors were large round heavy things, like the wsw motor, get the somewhat later ones, black and flat on two sides.....
for some reason the p/w regulators with that sector gear were prone to gross rust out, so some of the rebuilts are with stainless sector gears, Mine are not, I just keep them slathered n grease.....
the regulators mount up to the door, no sweat, whole thing not a issue, and mate to the stock tracks, which BTW need removed completely taken apart, and soaked overnight in a pan of gasoline to remove all that dried out caked on grease and crud.....assemble totally naked, no grease, if the rollers are fubar get new ones.....
btw, window switches are from donor cars in the junkyard.....and I did not bother with any ignition interlock relay, mine go up/dn as the switches are always hot....
I'm looking to go the other way with this...that is, convert from power to manual to save weight. If anyone wants to get rid of some of their manual parts, please let me know!
However, my right side window goes up very slowly and I have to open the door for it to go up all the way. Just FYI in case we can make a deal. PM me your email and we can talk offline.
