Electric Fan?
Old Jan 19, 2009 | 02:11 PM
KW's Avatar
KW
Default Electric Fan?
Going to run a dewitt elec.fan set up on my 71
Question ? the car has air need to know what pully set up
I will need to set everthing up. It also has power steering
will more the likley run a March v belt so if you know the
part #'s that would be great
Thanks for any info
Old Jan 19, 2009 | 02:17 PM
SIXFOOTER's Avatar
SIXFOOTER
With the electric fan setup there is not much to do other than remove the existing fan, clutch and radiator shroud and install the new rig per instructions. You will need new bolts to hold the waterpump pulley in the shaft.
March has a bunch of setups, someone will pipe in with what they used. I used a serp setup from an 88 vette.
