found some heads in the barn,
Old Jan 20, 2009 | 09:40 PM
carlos85vette's Avatar
carlos85vette
Default found some heads in the barn,
I found a pair of BBC heads in a barn and I got the part # off of them it says High Perf cast into the top of the casting the part number is 3964927 can anyone identify them?
Old Jan 20, 2009 | 09:58 PM
vettesbydesign's Avatar
vettesbydesign
Check the numbers again.I'm not seeing that casting.
Old Jan 21, 2009 | 10:22 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Maybe they're 3964291's, '70 LS6 Chevelle heads??
BTW, did you get the 6x2's out yet, Kev?
Old Jan 21, 2009 | 10:31 AM
hugie82's Avatar
hugie82
Oval or square port???
Old Jan 21, 2009 | 11:36 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Clean casting # well and check again. Square port of oval port. Post casting date also. Should be this configuration. (example) E 7 70
Old Jan 21, 2009 | 11:53 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
http://www.mortec.com/bbc.htm
Old Jan 21, 2009 | 05:52 PM
carlos85vette
Default barn heads
The whole # is 72396492[7]or it might be a 1 -oval port-cast iron
Old Jan 21, 2009 | 06:09 PM
63mako's Avatar
63mako
Clean casting #, post date code!!!
3964291 is the closest I could find
3964291....69-72...rect..CLOSED..396, 402, 427, 454, 109cc chamber, Large or small hex spark plugs used, crate motor usage in years after 1970.
Old Jan 21, 2009 | 06:13 PM
TheSkunkWorks
Look again at the last 4 numbers to make sure you're not transposing numbers. Believe you may find it's ...4291, which should make these the '69-'72 109cc closed chamber, rectangle port, hi-perf iron heads suspected. Depending on date code, could be off any number of original applications including 402 L78 or 454 LS6, off of a '70 or later crate engine, or replacements.
Old Jan 21, 2009 | 11:00 PM
vettesbydesign
I got them on,and had a serious intake leak.did I mention....serious????I got frustratedmabd put the 750DP on a Torker,and getting ready to go back at it.Once I got going...wow..The aluminum heads,new cam,and 1.6s really brought the car to life.
I am trying to get some stuff out of the way here to get paint on it this spring.HOPEFULLY!!!!!!
To found some heads in the barn,
