Radiator hose ??
Old Jan 22, 2009 | 02:21 PM
kend47's Avatar
kend47
Default Radiator hose ??
I had both upper & lower hoses replaced when I had the Vette (77 L-48, auto) in for some other work. How can I tell if the lower hose has the metal coil in it? I ordered a replacement from Zip and there was no coil that I can see. I have an over-heating problem and I think it might be the lower hose collapsing. Can you buy the metal coil?
Old Jan 22, 2009 | 02:26 PM
imariver's Avatar
imariver
just squeeze it, you'll be able to feel the coil inside
Old Jan 22, 2009 | 03:17 PM
Durango_Boy's Avatar
Durango_Boy
You can usually feel the spring inside better after the car is warmed up a bit too as opposed to cold.
Old Jan 22, 2009 | 03:47 PM
kend47's Avatar
kend47
The replacement hose from ZIP is AC Delco ACD# 26040X GM# 88908738. I do not feel any metal in the hose. Is this the correct hose? I've seen pics where the metal can be seen.
Old Jan 22, 2009 | 04:00 PM
Paul L's Avatar
Paul L
The squeeze test will do the job. These hoses are not expensive. Just get the right one.
Old Jan 22, 2009 | 06:51 PM
Roscoe's Avatar
Roscoe
[QUOTE=paul 74;1568652498]The squeeze test will do the job. These hoses are not expensive. Just get the right one.
Made in Mexico.
What are you going to do.
Old Jan 22, 2009 | 07:17 PM
Paul L's Avatar
Paul L
Use it. The engine in my new daily driver Impala was made in Mexico. One of the best cars I have ever owned. Get used to global sourcing.
To Radiator hose ??
