1973 T-Top L82 Project
Old Jan 23, 2009 | 09:18 AM
Marconi's Avatar
Marconi
Cruising
Default 1973 T-Top L82 Project
Here we are again...
As I was telling you on the other thread the car is arrived in Mid-november and now she is in her room.
here some pics...
Old Jan 23, 2009 | 10:03 AM
Marconi's Avatar
Marconi
Cruising
On Mid-February I would to start (and finisch)order engine parts
I have just seen different things like these:
what do you think about?
EAGLE Balanced Rotating Assembly, Competition, Forged Crank, Forged Pistons, H-Beam Rods, Small Block Chevy, Kit oversize + 0.060 in.
Sample Link
DART Cylinder Head, Pro 1, Aluminum, Assembled, 64cc Chamber, 200cc Intake Runner, Chevy, 327/350/400, Each
Sample Link
COMP Cam/Lifters/Valvetrain, like this but not necessarily equal Mechanical Roller Tappet, Advertised Duration 268/268,Lift .525/.525,Chevy,Small Block
Sample Link
CRANE Rocker Arm, Shaft Mount, Full Roller, Aluminum, 1.6/1.55 Ratio, Chevy, Small Block, Each
Sample Link
AEROMOTIVE Fuel Pump, Electric, A1000 Series, External, Universal, Each
Sample Link
AEROMOTIVE Fuel Filter, Inline Mount, Aluminum, 100 Microns, Red, -10 AN Female Inlet/Outlet, Each
Sample Link
Combo, TCI Flexplate 168-Tooth/ Balancer neutral ARP Bolts, Chevy 1986-94, 5.0/5.7L, Kit
Sample Link
EDELBROCK Water Pump, Mechanical, Long, High-Volume, Aluminum, Natural, Chevy, Small Block, Each
Sample Link
FEL-PRO Gaskets, Full Set, Chevy, Small Block Gen I, Set
Sample Link
HOOKER Headers, Super Competition, Full-Length, Steel, Ceramic Coated, Chevy, Corvette, Small Block, Pair
Sample Link
MILODON Oil Pump, High-Volume, Chevy, Small Block, Each
Sample Link
MOROSO Vacuum Pump, Racing, 3-Vane, Aluminum, Black Anodized, Each
Sample Link
Old Jan 23, 2009 | 10:21 AM
wnmech's Avatar
wnmech
Great looking project keep the pictures coming.
Old Jan 23, 2009 | 09:38 PM
DC3's Avatar
DC3
Bump to the top for you so maybe the engine guys will see and respond to your questions.
DC
Old Oct 21, 2009 | 10:27 AM
Marconi's Avatar
Marconi
Cruising
Here I am again
after a hard summer where my work has taken
much time and a mopar 318 of a friend of mine the remaining
It's now time to start the project really..
Santa Claus came early this years
here some pics:
Old Oct 21, 2009 | 10:37 AM
Marconi's Avatar
Marconi
Cruising
When the charger engine was finished
the idea of starting engine out of the car bring me to make this
obviously is right also for chevy
Old Oct 21, 2009 | 06:01 PM
Alan 71's Avatar
Alan 71
Hi Marconi,
I enjoyed looking at all your pictures.
You must have been a VERY good boy for Santa to bring you all those great parts for Christmas , and EARLY no less.
I'll look for your up-dates.
Regards,
Alan
Old Oct 22, 2009 | 09:33 AM
08vycpe's Avatar
08vycpe
Great pictures. I'm sure you will have a very nice car. Keep us posted. Also, check back here every now and then as there are some very knowledgable people here. You can get a lot of tips about performance, suspension, maintenance, comfort, etc.
Why not get the engine dyno tuned while it is out and the car? It's a good chance to run the engine in case there are any problems and can be tuned to max performance.
Is that a build sheet on the top of the gas tank? If so get it off and preserve it in a safe place.
Old Oct 22, 2009 | 02:02 PM
Marconi's Avatar
Marconi
Cruising
Thanks to all...
yes of course I'll test engine out of the car first...
build sheet is already in a safe place
To 1973 T-Top L82 Project
