L89 Question
Old Jan 26, 2009 | 11:45 PM
mdj89's Avatar
mdj89
Default L89 Question
How many L89 427 tri power engine were built ?
Old Jan 27, 2009 | 12:11 AM
69elky's Avatar
69elky
Default L 89
Just using the numbers printed in the Corvette Black Book,not over the counter.67=16,68=624 and 69=390,total 1030
Old Jan 27, 2009 | 12:39 AM
mdj89's Avatar
mdj89
Old Jan 27, 2009 | 05:53 PM
Ironcross's Avatar
Ironcross
..How many with T 400`s?
Old Jan 27, 2009 | 06:07 PM
427basketcase's Avatar
427basketcase
By the factory? or by Pro Team?
Old Jan 27, 2009 | 06:46 PM
Ironcross's Avatar
Ironcross
Factory, I didn`t consider some one would try to make one. I have only seen 1 and it was a 1969 Maroon coupe and beigh interior. A Very pretty car
Old Jan 27, 2009 | 08:33 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Good call
Old Jan 28, 2009 | 10:03 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The information may not be available and might be none. If memory serves, the TH400 could be ordered with the L36 and the L88 but not with the L71.
You could purchase the aluminum heads over the counter at Chevrolet and add them to any big block and that could account for the '69 you ran across.
Old Jan 28, 2009 | 10:09 AM
halfmoontrail's Avatar
halfmoontrail
(255) 435 hp cars built with TH400 in '69, none in '67 or '68. No available breakdown on how many were L89 versus L71, but it is a small number.
Just assuming approximately 10% of L71 were TH-400 (255/2722); and applying the same ration to L89 would be about 40 L89 with TH-400.
L71/L89 with TH-400 is a rare and desirable combo. My L71/TH400 is not quite roadworthy yet, but those who drove the car in its past life, and the owner of another one, describe the performance as AWESOME. It was a special TH-400 (CY code, maybe a few CX codes).
Steve
PS: One of the known ZL-1 is a "CY" automatic, and I think some of the Camaro ZL-1s were also, maybe 15 of 69?
Old Jan 28, 2009 | 10:12 AM
halfmoontrail
Mike,
255 were confirmed by Chevrolet as built with 435 hp (L71/L89) and TH-400 for 1969.
Mine has other surprising options including power brakes and power steering.
Steve
Old Jan 28, 2009 | 10:37 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by halfmoontrail
Mike,
Steve
Thanks for the info. I learn something every day.
Old Jan 30, 2009 | 07:42 PM
Ironcross's Avatar
Ironcross
Mike,
Steve
How long have you had it?
Old Jan 30, 2009 | 11:02 PM
early shark's Avatar
early shark
You need to get the Tonawanda engine facilities records to know how many were actually built.
As an example, Tonawanda records indicate 212 engines coded for 1971 LS6 application either as CPX or CPW. Chevrolet records indicate 188 of these installed in production vehicles, leaving 24 for warranty purposes or ?
So the production of L-71/L89 engines will be higher than what is listed in the Corvette Black book stats.
To L89 Question
