question for Pioneer CD player remote control
Old Jan 28, 2009 | 09:03 PM
Georgia1974's Avatar
Georgia1974
Default question for Pioneer CD player remote control
Hope someone can help me
I have a Pioneer CD player with remote control
Hooked everything up and it sounds great, but there is a blue and white wire for the system remote control. It says to hook to the system control terminal on the power amp or the antenna relay control. I do not have either. Can I just hook up to 12V power ? I have quick disconnects for my battery so I am not concerned about battery drain. But want to make sure I am not missing something.
Old Jan 28, 2009 | 09:58 PM
DC3's Avatar
DC3
The remote wire is designed to work with compatible amps and power antennas and will turn them on and off when the head unit is turned on or off. If you don't have an amp or a power antenna that can use this feature, this wire should not be connected to anything. Just tape it up and hide for future use.
DC
Old Jan 29, 2009 | 08:37 AM
Durango_Boy's Avatar
Durango_Boy
DC
Yep, that wire carries a very small signal to tell the antenna and amp to turn on, so it IS a 12V source and doesn't need to be connected to one. That would short out your head unit.
As mentioned, just tape it up so it won't touch anything and leave it be.
Old Jan 29, 2009 | 08:41 AM
BTAL's Avatar
BTAL
St. Jude Donor '09
Or you could use it to activate your disco ball.
Old Jan 29, 2009 | 09:03 AM
Georgia1974
Great info tape it is
Thanks everyone
To question for Pioneer CD player remote control
