Hooker Headers
Old Jan 29, 2009 | 11:39 AM
chivic's Avatar
chivic
Default Hooker Headers
Does anyone know where I can get the mounting hardware to mount the hooker side pipes? I bought a used set and there isn't any hardware included. Thanks, Chip
Old Jan 29, 2009 | 11:49 AM
Durango_Boy's Avatar
Durango_Boy
You can get it from Hooker direct, or through a vendor that sells Hooker, like Ecklers or Mid America. I know someone who ordered the mounting hardware kit from Mid America. You can also get A/C bracket and alternator brackets to adapter with the kits. Inserts might also be needed.
Old Jan 29, 2009 | 02:11 PM
chivic's Avatar
chivic
Thanks DB. I knew I had seen them for sell some where, but couldn't remember where. I already have the alternator brackets. I just wasn't sure if you could use another type of bolt or not. Thanks again, Chip
Old Jan 29, 2009 | 07:10 PM
addballer696's Avatar
addballer696
i had the same problem when i bought my sidepipes. I just got some hardware from lowers and used some of those rubber circle things you put underneath heavy chairs to accomidate for the flexing. worked fine for me
Old Jan 30, 2009 | 01:28 AM
bobl.2's Avatar
bobl.2
Default Hooker sidepipe headers
When I origionaly bought tje set up, all the hardware came in the same box as the tubes. I don't know if this is true anymore however, you may go into hookers web site under side tubes, and see if there is a hardware package available for that application.Good Luck!
To Hooker Headers
