1969 Muncie transmission identification
Old Feb 9, 2009 | 01:32 AM
1996ta's Avatar
1996ta
Default 1969 Muncie transmission identification
Trying to ID the trans (M21, M22, etc...). Vertically on the side of the trans is the date code P8K12 (not P9K12, even though it's a 1969 car) and the other set of numbers after the 19S match my VIN. It has no suffix (A, B, or C) after the P8K12, but it seems suffixes were used after October 1968, so the lack of the suffix seems to make sense (the P8K12 code makes a July 12th date if my research is correct). Are there other codes on the trans to help ID the trans type?
Edit - By the way, I dropped the tank, hoping the tank sticker would ID the trans type, but the sticker was nowhere to be found.
Old Feb 9, 2009 | 01:42 AM
71coupe454's Avatar
71coupe454
I just went through all this with mine, this should tell you everything..
http://www.5speeds.com/casting.html
http://www.5speeds.com/muncie2.htm
Old Feb 9, 2009 | 01:56 AM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
appreciate it. I can use those
Old Feb 9, 2009 | 05:06 AM
vettesbydesign's Avatar
vettesbydesign
is the casing a 010?How many grooves,or no grooves ar on the input?
68s didn't have the A,B,or C codes to identify.You were able to tell by the groves on the 10 spline input.
Old Feb 9, 2009 | 12:45 PM
early shark's Avatar
early shark
The transmission main cases prior to '71 model year did not use two screw in plugs (one for filling, one for draining), if you had an M22 it would have had two plugs, so that should eliminate this choice from the three possible.
Old Feb 9, 2009 | 03:04 PM
wfo76's Avatar
wfo76
The 8 (model year) would be problematic for a 1969 car.
What engine did the car have originally?
L36/L68 had M20 or M21 available, L71/L89 was M21 only and L88 was M22 only.
Old Feb 16, 2009 | 11:41 PM
1996ta's Avatar
1996ta
Thanks all for the info.
I'll have to check for the casing codes when time frees up. I don't remember the # of drain/fill plugs it has; will have to check for that, too.
I think it is an L71 car; it's got the correct tach, console plate, HD rear, etc... but the block is incorrect and could not locate the tank sticker. I dropped the tank a few weeks ago for that but no sticker was found. Was the correct HP tank, though.
Old Feb 17, 2009 | 11:37 AM
CCrane65's Avatar
CCrane65
Just checked the Technical Manual and Judging Guide and I was wrong, it is the model year.
cc
Old Feb 17, 2009 | 11:51 AM
wfo76's Avatar
wfo76
I would ask the original poster 1996ta how early of a 69 he has. I guess it is possible the that the tranny
had an issue and was sent back to Muncie and then sent back to STL for installation in his car.
The question is would the original stamp stay or would Muncie grind it out and restamp it?
Old Feb 20, 2009 | 05:36 PM
1996ta's Avatar
1996ta
It's a later 1969 car, vin is 727XXX. Is that a July or August car?
The stamp areas were not grinded or anything; the textured surface immediately around the numbers is unmarked.
Old Feb 20, 2009 | 11:15 PM
CCrane65's Avatar
CCrane65
If you still have the trim tag on the drivers door hinge pillar the build date code will be on it in the upper right hand corner.
cc
BTW, July or August would be early car of the next model year. Late cars are May, June.
Old Feb 21, 2009 | 09:25 AM
schmegeggie's Avatar
schmegeggie
The P8 would indicate that your transmission is from a 1968 model year. Second to that, there is no suffix, which began Oct. 21, 1968.
The housing code should be 3925660.
Old Feb 21, 2009 | 04:16 PM
vettebuyer6369's Avatar
vettebuyer6369
Oddities are out there. I looked at the case number on my car, found off to the right from your date/VIN and horizontal, not vertical, and it's 3925661... part number listings show 660 for 68-69 and 661 for 1970 and later. However, the car is so late a 1969 car (November) it must be that fuzzy line...
Old Feb 22, 2009 | 04:13 PM
1996ta's Avatar
1996ta
Yes, oddities are definitely out there. Fellow CF member (2-13-09 post date, 7:39pm) has the same exact issue:
http://forums.corvetteforum.com/c3-g...ssion-pic.html
Old Feb 23, 2009 | 10:18 AM
wfo76's Avatar
wfo76
I think there is too much of a gap in time for this to be the original transmission.
Your tranny date is July 68 and car's build date is August of 69, and don't see
any way the tranny hung around GM for 13 months.
What does the VIN stamp on your engine look like?
The two stamps were made by the same person at the same time so both the
engine and tranny stamps should be the same.
You can also find out if it's an M20 or M21 by the drop in rpm going from 3rd to 4th.
Go on the road at exactly 2000 rpm in 4th and maintaining the same mph, downshift to 3rd.
If the revs go to about 2900, it is an M20, if they go to about 25-2600 it is an M21.
Old Feb 28, 2009 | 05:18 PM
1996ta's Avatar
1996ta
The engine was decked so has no vin stampings.
Makes no sense somebody would go through all the trouble to re-stamp a trans and not use the P9 code. Plus, there's no markings or blemishes around the trans stamps indicating a re-stamp. I'm sure it's original, just one of those things that happen, just like the guy's trans above. Not sure how it is with Chevy's, but my old GTO had the original engine/trans and the engine was coded with a 2 where a Z should've been (the trans used the Z). Things happen when humans are involved.
Thanks for the RPM drop info, that helps quite a bit
Old Jun 5, 2012 | 02:44 PM
vettedab's Avatar
vettedab
Cruising
Another oddity out there. I also have a '69 BB convertible with a Muncie P8K coded tansmission. VIN # stamp identical on engine pad and transmission. Car produced in July 1969.
To 1969 Muncie transmission identification
