The Blaupunkt subwoofer has two power (+) leads and two ground (-) leads. Why I do not know. But according to the instructions they are to be joined at installation and the (+) side fused. The amp has an internal fuse of 10A and I assume the (+) connection will be 10A as well (the instructions do not say). Those wires are 16 gauge.
My intent is for both (+) and (-) to go directly to battery posts, GM side version. I have been poking about at on-line electronic stores and there are certainly a lot of many connectors out there. But most are for much larger amps and wire gauge. Does anyone have suggestions as to how to make the connections and what fuse holder to use? Garden variety white nylon type? Is the connector the simple loop/ring variety? I would appreciate advice and pics if available.
Guys, I was told by a mod that DB is no longer on this forum.
WTF!
I was thinking of running Polk Audio db 525 in the kick panels and MMC461p's in the dash wired in parallel so they run at 2ohms. That way I can hear the radio over my really loud exhaust. (and my bitching wife that the car is too loud).
I can tell you that DB always maintained that dash speakers are not necessary when you have good speakers in the kick panels. In fact he said they tend to make the sound too bright because of their small size.
cc
Yes, that was his advice to me. Hence my course of action. The current Pioneer 4 x 6"s in the upper dash will be disconnected and the Polks in the kickpanels will do the front end action. The Blaupunkt in the rear will take care of bass. DB provided me with a nice plan that did not require an amp for the 4-ohm front speakers.
As to whether DB is needed, much of what is being discussed in this thread is a result of his initiatives. My thanks to him. It is unfortunate if he is no longer with us.
cc
It's not the small size of the speaker but the placement of the speaker reflects off the windshield and with this the sound is even brighter. There nothing wrong with dash speakers you just need to control the volume of them so that don't over drive the other speakers.
The best set up is a mid and tweeter in dash a 6.5 or 5.5 midbass in kickpanel, a sub and midbass to midrange for rear fill.
I suppose all four up front could be drive by a 50W x 4 head and the subwoofer in the back by its own amp. I can't see any harm in trying that with the dash top (front) speakers controlled by fade. This should be an interesting experiment!
The factory tweeters in my Suburban's Bose system are actually pointed at the windshield and designed to reflect off of it.
At a show last year I listened to DB stereo setup and I have to agree that it is a sweet setup... very straightforward and simple but good crisp mids and highs with deep booming bass... I liked it a lot and plan on doing my 72 like that. it will be a loss if he is no longer on this forum.
ttt. I am still interested in the amp's fuse/(+)/(-) connectors at the battery side terminals. Pics would be nice.
In your battery compartment there is a positive lead that goes to a distribution block. My car is an 81 and the block is to the right of the battery. I think you have a 74 which maybe different. Connect power to the distribution block and connect ground as close to the amp as possible.
You can go to the neg post. Try it, if you get noise you have to move it to a piece of metal that makes ground. For the positive side get a ring terminal without the plastic insulator, crimp your wire and then take a hammer and flatten the crimp. This makes it easier to connect the side terminal back to the battery. Place a fuse at the battery to protect the wire. If it ever grounded without a fuse, it will burn the wire
This is what I will install on the power (+) side. The integral amp on the subwoofer has a 10-amp fuse in the chassis so I thought that this would be fine for the battery end. The ring connector is soldered and shrink-wrapped.
Thats fine but you might want to go a little thicker for power, I'm thinking 12 or 14 guage. Can't tell by the pic but that wire looks a little thin
The fuse-holder is 16-gauge but given that two 16-gauge (+) wires from the subwoofer amp (see above pics) will be going into it I may switch to 14- or 12-gauge. The Blaupunkt is a strange setup....
I've taken 12 or 14 guage fuse holders and cut out some of the strands so I could solder it to the crimp like you did. This way you have a heavier guage wire runnig to the fuse and amp.
DB has been banned. He says he is not sure why and the moderators are not responding to his e-mails. It is too bad because he was a great source of information. I wish him good luck!
