Kick panel/speaker question...Where's D_B
Old Feb 9, 2009 | 08:22 PM
BritewhiteC3's Avatar
BritewhiteC3
Default Kick panel/speaker question...Where's D_B
I hope to get a reference on which speakers to buy and maybe a template to modify the kick panels
Old Feb 9, 2009 | 10:24 PM
sdonnelly's Avatar
sdonnelly
DB must be at Hooters. Try the search feature.
Old Feb 9, 2009 | 10:55 PM
MakoShark72's Avatar
MakoShark72
You just might want to email him......
Old Feb 9, 2009 | 11:20 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Polk Audio 6.5" coax speakers
Old Feb 9, 2009 | 11:24 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Looked high Looked low.......DB were did you go
Old Feb 10, 2009 | 03:33 AM
Droptop-Rob's Avatar
Droptop-Rob
This will get you stated mean while:
http://forums.corvetteforum.com/c3-g...ck-panels.html
http://forums.corvetteforum.com/c3-g...-for-30-a.html
Old Feb 10, 2009 | 08:03 AM
BritewhiteC3
I don't know..... but I'll look left and right
Old Feb 10, 2009 | 08:21 AM
stevekk's Avatar
stevekk
6 1/2" Polk Audio. These speakers came with a plastic adapter ring which I glued to the backside and used as a template.
Old Feb 10, 2009 | 10:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Stock 4x10s and 4x6s will fit behind the kick panels without having to cut anything.
Old Feb 10, 2009 | 10:25 AM
xCCTer's Avatar
xCCTer
CF JASOC Member
From: Downtown Annapolis, MD. The Future is where we all have to live. Let's not screw it up.
Yep. Polk Db651s.
The placement has to be exact for the magnets to fit in the birdcage void.
http://www.polkaudio.com/caraudio/products/db651/
Old Feb 10, 2009 | 12:26 PM
Corv3tt3's Avatar
Corv3tt3
Maybe he was banned.
Old Feb 10, 2009 | 01:39 PM
Paul L's Avatar
Paul L
Xccter,
There must be a little bit of leeway on placement of speakers on the kick panels....
To Britewhite,
This will be my system for 2009. The kickpanel speakers are Polk DB651 (6-60W RMS, 180W peak, 6 1/2") as noted above. The subwoofer is Blaupunkt THb 200 A with integrated amplifier (70W RMS, 140W peak, 8"). It will be placed/screwed down on the back shelf.
This combo should be adequate for my modest needs.
Old Feb 10, 2009 | 02:20 PM
RagTop69's Avatar
RagTop69
Do they sound reasonably decent? I'm no audiophile and all I want is some sound that I can hear in the front of the car. The P.O. installed one of those rear speaker bars and disconnected the kick panel speakers in my 69. His stereo guy said they would need to install an amp to drive all of them, so he picked the new ones. You can't hear anything at speed. I have small (4" x 6") 2 way door speakers in my Mustang vert and they are great. They can be heard with the top down, no problem. How bad can the stock type be?
Old Feb 10, 2009 | 07:47 PM
74Blackfoot's Avatar
74Blackfoot
For a template, look no further than the box the speakers came in. Normally there is a square piece of cardboard that stabalizes the speaker in the box. Just take that out and take the pieces of the speaker and mark the ring a little bigger, cut it out then use that as a pattern to marker the kick panel.
Polk Audio 6.5" is the biggest you can go unless you want to start cutting the birdcage and fabricating/modifying kick panels because of the size and displacement of the magnet.
5 1/4" speakers will fit with out having to cut on anything except the kick panel, they don't look like they are taking over the kick panel either. Picture below for those that want to compare to the larger 6 1/2".
Just do a search for kick panel speakers and you will get all sorts of results and various write ups (Lots of good detail) by the guys here.
Paul your speakers look sharp, did you paint the rings or dye them?
Blackfoot
Old Feb 10, 2009 | 08:14 PM
Paul L's Avatar
Paul L
I get custom vinyl dye (oxblood) from my local AC Delco paint place. They do it up in a paint can for about $20.00.
They also provide me with exterior paint (Medium Red Metallic). The gas door on a 1974 does not have an emblem so I will be using this 1975 version with sunburst next summer.
Old Feb 10, 2009 | 08:27 PM
RobRace10's Avatar
RobRace10
Originally Posted by paul 74
Xccter,
To Britewhite,
I just ordered the Blaupunkt THB200A ($149.00 also and some dynamat extreme ($129.) . They have a special on both, free shipping and an additional Valentines day $15.00 discount on orders over $200.
http://www.dealercostcaraudio.com/se...upunkt+THB200A
http://www.dealercostcaraudio.com/10455.aspx
http://www.dealercostcaraudio.com/bemine09.aspx
Discount Code - bemine09
I can't decide on a head unit yet, so many out there.
Old Feb 10, 2009 | 08:46 PM
BritewhiteC3
Default Thanks for the replies
Wow lots of good info to consider...... Didn't need whatshisname after all.
Thanks guys
To Kick panel/speaker question...Where's D_B
Old Feb 10, 2009 | 11:41 PM
xCCTer's Avatar
xCCTer
CF JASOC Member
Thanks guys
I got most of my info beforehand from "whatshisname".
Old Feb 11, 2009 | 03:29 AM
RunningMan373's Avatar
RunningMan373
Let me just comment,, after playing around with several combos, I arrived at a 'What's his name' type system. That is, 2 excellent quality door speakers, a 4 ch amp , and a 10" sub behind the drive (pointed AWAY from the driver). Can't go wrong with this system. I chose the Infinity Kappa 62.9s for the doors (a 2 Ohm speaker, so must be driven by an Amp) and they need a 1/2" spacer, 'cause the magnets ain't play'in ,, With a 4 Channel amp, ch's 1 & 2 drive the kick panel speakers,, bridged ch's 3 & 4 to drive the sub, done.
Old Feb 11, 2009 | 11:03 AM
74Blackfoot
Thanks Paul. After seeing pictures of the rings dyed it makes the speakers look like they are stock, if you never knew they weren't. This will probably be the next thing I do. Anything to keep from starting the body-off.
