What Causes This
Old Feb 11, 2009 | 09:26 AM
Tim81's Avatar
Tim81
Default What Causes This
After running my 81 for awhile, I notice a anti-freeze smell. After a careful investigation I found anti-freeze sitting on the left and right front intake manifold bolts. The thermostat housing and hoses are fine and are not leaking. Where is this anti-freeze comming from?
Thanks for all information Tim
Old Feb 11, 2009 | 09:44 AM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Sounds like your intake manifold gaskets are starting to leak. Coolant can also weep up the intake bolts.
Old Feb 11, 2009 | 11:36 AM
7T1vette's Avatar
7T1vette
With engine 'cold', remove the bolt(s) having coolant leakage (around the threads). Blow the coolant out of those threaded holes or allow them to dry out. Wipe some Permatex non-hardening gasket sealant on the bolt threads. Re-install and torque the bolts to 30 ft-lbs. That should stop the 'weeping' of coolant at the bolts. Keep a good watch on the engine oil to make sure no coolant is contaminating it; that would indicate a crack in a cylinder head at/near a bolt hole.
Old Feb 11, 2009 | 11:42 AM
Tim81's Avatar
Tim81
Thanks for the tip. I will try that and hope for the best.
Old Feb 11, 2009 | 12:22 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
not sure if this helps but i had a similar smell in my old gto when driving. found liquid on the passenger side carpet. come to find out the heater core was leaking.
Old Feb 11, 2009 | 02:27 PM
Brandywine's Avatar
Brandywine
You also might want to drop the oil pan and see if any coolant got into the oil...
Old Feb 11, 2009 | 02:35 PM
Tim81's Avatar
Tim81
If there was coolant in the oil, wouldn't I see it on the dip stick? Or would it be best to drop the pan?
Old Feb 11, 2009 | 02:38 PM
Vampyre's Avatar
Vampyre
Maybe not on the dipstick, but your car would smoke when running
Old Feb 11, 2009 | 02:42 PM
FormerBiker's Avatar
FormerBiker
Easier than dropping the pan try pulling a valve cover and look for a whitish creamy substance. That mean water in oil.
Old Feb 11, 2009 | 02:59 PM
Brandywine's Avatar
Brandywine
The reason for dropping the pan is you now have quick access to the main bearings. If you find a milkshake in the pan, the first thing I'd do is pull a bearing and inspect it. My .02
Old Feb 11, 2009 | 04:00 PM
bashcraft's Avatar
bashcraft
You'll see that on the stick. If you're still unsure, just drain the oil. Then you'll know. You don't want to pull the pan unless you're absolutely sure there's a problem. Unless you enjoy wasting time.
Old Feb 11, 2009 | 04:48 PM
Paul L's Avatar
Paul L
Permatex 2 on the intake bolt threads will solve this problem.
Old Feb 11, 2009 | 05:02 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I had the same problem w/my thermostat housing stud... a little permatex on the threads took care of it.
Old Feb 11, 2009 | 08:23 PM
dannyman's Avatar
dannyman
Originally Posted by Tim81
found anti-freeze sitting on the left and right front intake manifold bolts. Where is this anti-freeze comming from?
There's your answer. "From the bolts."
Check your oil and anti-freeze for cross contamination; but it sounds like you only have anti-freeze seepage at the bolt threads. Sealing the bolt threads will address your issue.
Your gasket would have to be blown to have further problems.
Old Feb 11, 2009 | 09:17 PM
Tim81's Avatar
Tim81
Thanks everybody for your helpful advice. I plan on pulling the valve covers to change the leaking gaskets, so that should tell the tale. There are a lot of miles on the motor, but it runs just fine. Hopefully I will be driving it instead of rebuilding the engine.
Thanks Again....Tim
Old Feb 12, 2009 | 12:54 AM
71coupe454's Avatar
71coupe454
just do the bolt or two you think it is. I wouldnt take to many bolts out at the same time if your not changing intake gaskets, which you dont need to do at this point.
Old Feb 12, 2009 | 06:24 AM
corvetteload's Avatar
corvetteload
Yes, drop the pan in an extensive labor inducing procedure-----------or just change the oil?!?!?!?!?! What a dumb suggestion--to drop the PAN!!!!!
Old Feb 12, 2009 | 07:34 AM
L88Plus's Avatar
L88Plus
Let it set for a few days so the water/antifreeze and oil will separate. If you have a substantial amount of water/AF in the oil, it'll show since it'll be the first stuff out of the pan.
To What Causes This
