Info plate on console
Old Feb 11, 2009 | 12:16 PM
kansas123's Avatar
kansas123
Default Info plate on console
Does anything on that info plate on the console indicate what rear end I have. It says 360 Ft Lbs and also 8.5:1 comp ratio. Thanks. it's a '72 350 auto
Old Feb 11, 2009 | 12:23 PM
CCrane65's Avatar
CCrane65
David, sorry but no. You'll need to get it up in the air and get the numbers off the case unless you have the build sheet/tank sticker.
If you want to bring it over and put it on the lift I've been layed off so I have plenty of time.
cc
Old Feb 11, 2009 | 12:41 PM
CCrane65's Avatar
CCrane65
By the way, we are starting up a Kansas chapter of NCRS if you are interested in joining. We had our first meeting Jan. 28th at Davis-Moore Chevrolet and I was elected Chairman.
Our next meeting is scheduled for March 7 at 9:30am at Davis-Moore - upstairs.
cc
Old Feb 11, 2009 | 04:14 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your console plate is generic for all Corvettes with the same engine for your year. For some years, rear axle ratios were optional and could change from car to car.
Old Feb 11, 2009 | 04:19 PM
halfmoontrail's Avatar
halfmoontrail
P-O-P would also show the code.
Steve
PS: Sorry to hear about your employment challenges, hope that turns out for you.
Old Feb 11, 2009 | 04:33 PM
Alan 71's Avatar
Alan 71
Hi K123,
The codes for 72 are :
AA 3.55
AB 3.70
AC 4.11
AX 3.36
LR 3.36
AW 3.08
Good Luck!
Regards,
Alan
Please take CC's offer and checkout the NCRS, you'll like it!
Old Feb 11, 2009 | 05:40 PM
early shark's Avatar
early shark
kansas123,
You have two choices of rear axle ratios for that car. Std is 3:08 or Perf 3:36.
To Info plate on console
